Question about Mobile Rack Hardware Hard Disk Encryption IDE 5.25'' Mount for any 3.5'' IDE Drive (MBDES40) Drive Case
Ic level repairing
Cpu rebolling
  • 85 Answers
Er... could you elaborate?
Posted on Mar 15, 2008
Is there a free medical dictionary to use online thats compatible with nokia 5233
Problems or trouble typically found on mobile phones can be categorized into
Three damage categories, namely:
1. Software Problem category
2. Hardware Problem category
3. Problem Category his SW and HW
Phone problems and solutions
1. Total dead cell phone
Mobile phones exist three kinds of die total, die total because of
· Die alone,
· Total death due to falls, and
· Death total for the taxable water.
a. Total death because death itself.
Handling:
The first can be done early steps following
- Remove the battery and plug in again, or try using another battery and try turn it
- Check the battery connector and try the press to see the level of flexible or not,
replace damaged when new.
- Connect the charging of the phone, when the indicator on the phone in and still will not turn on, then obviously you can not live on mobile phones because of interference from IC PA (Power Amplifier). After IC PA revoked your mobile phone can turn it on again. And so no signal will be installed a new PA IC.
- When the tide does not exist and charging indicator on the phone still does not want to live on should be conducted further tests using power supply. But there may also have an ugly tin on the PCB, remove the IC PA solution, then clean the tin on the PCB where IC PA stick, replace the old IC PA, HP switch, it must be a flame.
Examination with power supply:
Necessary power supply on a scale of 1 ampere ampere (A) or 1000 mA.
With the aim that the examination can be more easily and clearly.
The steps are as follows:
- Connect the cable from the power supply to the mobile phone battery connector of at least three wires, with a negative sequence, BSI and positive. (Black, green and red)
- Navigate volt power supply at 3.6 V (or in accordance with tolerance Hp-0.5 V)
- Mobile phones in the state of OFF, and press the button on
- If the current (amperage) in a digital ampere dipower supply pointer when the button is pressed on, it just means there's still a problem on its hardware (HW), it is necessary to check the components on / off until the battery.
- When the ampere when the button is pressed on, up about? 50 mA, then the problem that occurs is a matter of software (SW), then you need to do is re-programmed HP (flash) or program is upgraded to higher versions.
b. Total death from falls.
Handling:
- HP may not be tested by using the power supply, but HP should be dismantled first, heated, and repositioned back to the location / position of the components has changed as a result of HP fell.
- After that, the new HP using the power supply should be tested to determine damage to the Hardware (HW) / Software (SW).
- Most likely a damaged components as a result of the fall is the HP PA IC / IC Power.
c. Total death due to hit the water.
Handling:
- For taxable HP water is also the first time should not be tested by using the power supply, because the risk of short circuit occurs between the components in water, but must first HP divakum, heated, or by first diblower given IPA cleaning liquid, can also use the grain silica to absorb the water that existed at HP.
- After HP confirmed it was dry, then we should use the power supply to determine the damage occurred on the Hardware (HW) or Software (SW).
- At HP's exposed to water, usually there is damage to HPnya accessories.
2. Total die because of IC phone UI.
In HP's case like this then requires test equipment that is power supply.
- Connect the power supply on the phone, give the voltage (volts) equal to 3.6 V (or in accordance with tolerance Hp-0.5 V)
- At the time the phone is in off state, refer to the power supply needles amperes will increase by 100mA.
- The phone will start, LED lights, VIBRA vibrate.
Handling:
- Remove the IC UI, then turn on the phone.
- Then there is the display on the LCD mobile phone "Insert SIM Card".
- Put new IC UI.
- Turn on the phone, the phone will work fine.
3. Total dead cell phone because the CPU IC.
To determine whether the cell phone because the IC die total CPU is as follows:
- Give the voltage (volts) on the phone by using the power supply of 3.6 V (or in accordance with tolerance Hp-0.5 V).
- At the time the phone is not turned on, the needle ampere silent, but if the phone is switched on then the needle will rise 100mA amperes.
Handling:
- If the IC CPU is still in good condition, then we only need to heat the IC CPU by using a blower, but if the CPU IC is damaged, then we need to replace with a new CPU IC. Before we replace our CPU IC must first have the anti-hot glue and liquid glue crusher anti-heat, because the CPU IC is protected by anti-heat glue, after we destroy the anti-hot glue, then we can heat (blower) CPU IC for a new replacement. Similarly, after we replace it with a new CPU IC then we need to give more anti hot glue to protect the new CPU IC we replace it.
4. Total dead cell phone when we call.
For testing we use the power supply by way of:
- Connect the phone with power supply, give the voltage (volts) equal to 3.6 V (or in accordance with tolerance Hp-0.5 V) on the phone.
- Needles amperes will not move when the phone is still in a state of death.
- We turn on the phone and then used to make calls, then the needle will show the number of amperes above 400mA.
Handling:
- Replace with a new IC PA, after re-testing was done as above, if the needle test results show the figures below 400mA amperes, the phone is in good condition.
Aug 26, 2011 | Nokia 5310 Cellular Phone
My nokia 2700 is not starting up , it got disconnected while updating , now its not switching on.. what shout i do plz help
problems or trouble typically found on mobile phones can be categorized into
· Die alone,
Handling:
Handling:
Handling:
Handling:
- Put new IC UI.
Handling:
Handling:
Aug 26, 2011 | Nokia Classic 2700 Cell Phone
The phone keeps turning off after every few minutes on its own. Have tried reinstalling the firmware but that doesn't help. Am at the end of my wits... Please help.
I would suggest you to first flash it completely so that there's no corrupted files.It's also important to refresh all the ics (ICs which can be given heat). Sometimes, this is related to Cpu and power ic which we can't repair manually or at local mobile repairing shops. You can visit the service center for their help.
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | Cell Phones
Phone does not ring. light flashes on top right of phone.
change the ringer and if complen rebol ringer ic
Feb 11, 2010 | Panasonic Lands Phones
My nokia 7610 shows white display.
its hardware problem. change display ic or reboll the display ic
Jul 05, 2009 | Nokia 1100
Display
hi first u change ur display and then rebol ur mobile's cpu. thanks and keep voting.
Sep 12, 2008 | Sony Ericsson K750i Cellular Phone
Dead
find driver 6681
Apr 02, 2008 | Nokia 6681 Cellular Phone
Phone shuts down
This type of problem occures in mobile phone due to followig reason...1..Defective software 2...Defective Key pad IC 3...Defective CPU IC.
First is cheaper and will be solved by any skilled technician.
2nd is Hardware problem and also can be repaired by techincian.
3rd is very werst thing. I pray it might be with your phone.
Key-pad scanning is overall duty of CPU IC of the phone. I advise you to contact nearby technician and ask him to put it right by software. He himself reply you what to do? Yes, this is paid service and he will charge you little. If u find it fixing your problem then do vote here.
Jan 08, 2008 | LG VX9800 Cellular Phone
Low contrast, adjusting contrast control has no affect. the bar does move back and forth. replaced caps around video procesor ic, also replaced an5165k ic.appreciate any suggestions thanks clinton.
You'll probably need a service manual for this one. You will have to check to see if the microprocessor is changing the voltage levels to the video IC as the problem could be with the CPU as long as the screen voltages are not out of whack at the CRT's or that they are bad.
Jan 25, 2007 | Panasonic PT-51G44 51" Rear Projection...
Mobile Rack Hardware Hard Disk Encryption IDE 5.25'' Mount for any 3.5'' IDE Drive (MBDES40) Drive Case Logo
67 people viewed this question
Top Mobile Rack Computers & Internet Experts
David Payne
David Payne
Are you a Mobile Rack Computer and Internet Expert? Answer questions, earn points and help others
