Question about Clarion DA-1030 Humidifier
How do I clean the heating coil and the humidifier?
Lost my manual. How do I clean the humidifier?
  • 131 Answers
Gently wipe, chip, and scrape as much scale as you can. If more cleaning is necessary, soak the pieces in vinegar.
Posted on Mar 12, 2008
How do I clean my Walgreren's 2065 humidifier
Easiest way to explain it is for you to go to then look for manual or cleaning instrutions/ Basiclly clean the filter by washing and vacuum units coils to remove dust.
Oct 20, 2014 | Humidifiers
When I first got the product, it worked great. Now there's hardly any steam coming out.
what is your water quality like. Anyway, unplug, and remove the screws from the underside of heating element. Pull unit apart and clean the heating coils, gonna have to scrap them with a utility knife. If you have hard water, deposits will build up on them , check them once a week if useing often
Mar 24, 2011 | Vicks V150SG 1 Gallon Humidifier
How close to heating coils to mount aprilaire 700
Hi google your humidifier can down load how to fix this in correct postion
Jan 22, 2010 | Aprilaire 700 Humidifier
Build up or busted?
more and likely it is calcium build up on the unit. especially if your using tap water. even if you cleaned it before putting it away for the season the build up can happen. if it's on the heating coil you need to get like a toothbrush and some vinegar water and lightly scrub the coils. now as far as the tank. let the tank soak in vinegar and water for about a half hour and then wash thoroughly. the portions is one cap full of vinegar per gallon of water.
Aug 20, 2009 | Vicks V5100N Humidifier
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Humidifier doesn't work as it used to,,,,,
First check to see if the two water sensing probes have been cleaned. After cleaning, if the problem still persists, try the following.
There is a small thermostat switch that sits on the heating coil underneath. This thermostat is designed to prevent the coil from overheating when no water is present. What probably has happened is the switch is doing what is designed to do but has become defective and is opening and closing at a lower temperature. So what is happening is the red light reset indicator will come on because this switch opens, the coil starts to cool and the switch closes and the light goes off. Because it is defective, this is occurring when it shouldn’t, causing this maddening on/off cycle.
Fortunately, this sensor is easy to replace if you’re handy. Make sure you unplug the humidifier from power. Turn it over, remove six screws, and carefully lift the lid. Look toward the heating element and you will see a small button type device with two wires plugged into it and is attached with two screws off to the side of the element. This particular thermostat is obsolete and very difficult to find. However, there is an excellent substitute made by Stancor for around $5.00. Their part number is STO-325.
Remove the two screws and lift off the thermostat and slide the wire connectors off. Simply reverse the process for installation and be careful to replace the bottom lid, being careful not to crimp the wiring.
Dec 07, 2007 | Slant Fin GF-210W 2 Gallon Humidifier
Clarion DA-1030 Humidifier Logo
124 people viewed this question
Top Clarion Humidifiers Experts
Paul Carew
Are you a Clarion Humidifier Expert? Answer questions, earn points and help others
