Question about HP LaserJet IIp plus Printer
HP LaserJet II p Plus will not print
I am attempting to print from my HP Compaq 6710b to my HP LaserJet II p Plus. (USB to Parallel). I am receiving an error in the Printing Status which states only ERROR - Printing. I can print a test page from the printer without issue. The printer is configured using Virtual USB port on the laptop. Could the printer itself be misconfigured. I no longer have a User Guide for the printer.
Thanks,
Christy
  • Hounddog01 Mar 12, 2008
    Thank you for your suggestions with the HP II P Plus. I am however using XP and not Vista. Are you aware of any compatibility issues with XP and the LaserJet? I realize the printer is quite old, but it still prints with the best quality!
    Thank you for your help.
    Brigadier General:
  • 6,966 Answers
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 12, 2008
  • Louie  Role
    Louie Role Mar 13, 2008
    Hi again,
    Appreciate your update. I was really about to answer your Live Chat/Session request but for some reason, I couldn't connect. That is what called my attention to your post.
    To my knowledge, there is no compatability issue with XP and the IIP Plus.
    What I am concerned with is the USB to Parallel Interface although that idea is the foremost solution one could think of considering the circumstances.. You initial post mentioned "Virtual USB port" which makes me think:
    1. it should not be virtual since the notebook has physically a USB port, probably would be;
    2. to my belief, it should be a "Virtual Parallel port" since the end user is parallel connected.
    If you can try winging it from there and look around your Printer Properties/Port Settings/Virtual Parallel port or
    you can try Add Port/New Port Type and use the driver/config CD that came with the USB to Parallel Interface.
    If still a nogo, as initially posted, you may have to consider using a mini print server connected to the parallel port of the printer. It can either be wired or wireless.
    Hope that this be of additional help. Pls post back for any developments (or lack thereof).
    Cheers.
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Just got a new computer. Have an old HP Laserjet
you have to refer to usb/ parallel converter manual, not printer manual
Apr 07, 2010 | HP LaserJet 4p Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
LaserJet IIIp will not print using USB to parallel cable via Vista
DOT4 USB Printing support must be installed and the printer setup on a USB port in the printer manager for this to work. The laserjet 3p driver provided by Microsoft does not natively support DOT4 USB printing, as USB was not even invented when that printer came out. You might be able to enable this support by using the HP Universal print Driver instead of the built in driver provided. You can get the universal driver here:
Jun 19, 2009 | HP LaserJet IIp plus Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
I am unable to get my trusty HP laserjet 4 plus to print now..... upgraded to a new desktop with USB ports only...my lj4+ only has serial and parallel ports. I used a serial to usb cord.... but not working...
Hi jragazoo:
There is a place called Tanner Electronics based in Carrollton,TX that can give you the information that you are looking for.
Tanner Electronics
(972) 242-8702
Jan 09, 2009 | HP LaserJet 4 plus Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
HP LaserJet IIp plus Printer Logo
459 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
