Installing more RAM
I am installing mor RAM MEMORY to my PC
I currently have 515mb in the first one of 2 Blue slots
There are 2 additional black slots with nothing in them
which slots do I use.
Ray Smith
  • raymon99 Mar 13, 2008
    I have already tried putting the 2 additional 512mb memory modules in the 2nd & 3rd slots, ie 2nd Blue one and 1st black one, and the PC will not start-uo.
    I have also tried 1 additional one in the 3rd slot, ie 1st Black slot, and also 1 additional one in the 4th slot, ie 2nd black slot with the same result
    Ray smith
    The model is an HP
    The Model No. is EC548AA-ABU a1128uk
    The Serial No. is CZB5350HHB G8530
    The Memory speed I am trying to fit is PC3200
    I got this from the information in PC Doctor
    Ray Smith
  • 59 Answers
It does not matter, but for the sake of me being kinda of neat freakish, I use the one closest to the allready filled slot
Posted on Mar 12, 2008
  • 1 more comment
  • Steve Bryant Mar 13, 2008
    are you sure it is the right speed of memory?  Make sure the memory is correct speed. What is the exact model of your computer?
    What is the exact model of your computer? Did you make sure you got the correct speed?
    I would take it back. The not turning on signifies a bad memory module. Return the memory and get a different stick
Alert! unsupported memory configuration. Please populate DIMM1
There should be 4 DIMM slots - two with white tabs and two with black tabs. DIMM 1 should be the white tabbed slot closest to the processor. Slots 1 and 3 (both white tabbed slots) should have RAM installed first, then slots 3 and 4 for additional RAM. If Slot 1 already has RAM in it, pull it out and push it back in to reseat it. If that doesn't work, replace the RAM in Slot 1.
Apr 18, 2014 | Dell OptiPlex 780 PC Desktop
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
I WILL REPAIR MY COMPUTER
Upgrade your RAM into 1GB or more, currently you are using 512MB which causes your system slowdown. On that model look for SoDIMM RAM with the DDR2 slot with 1GB or more. If you can see 2 memory slots, just buy additional RAM then put it on the blank slot.
Oct 06, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Can you put 2 igb memery into the blue connectors and 2 512 gb into the black connectors
Yes, provided;
A) The Maximum Total Amount for the Ram Memory is at least 3GB.
B) The Maximum Amount for each Ram Memory slot is at least 1GB.
C) The first blue connector is ram memory Slot 1. (DIMM 1)
The Processor 'sees' the Ram Memory in Slot 1 first.
If there is a large amount of ram memory, (1GB), and a small amount (512MB), the large amount goes in Slot 1.
ALL ram memory must be the same 'speed', (Frequency Rate), or the slower ram memory 'speed' will be used.
If there is too much of a difference it may not work at all.
Ram memory needs to be 400MHz, or 533MHz, for your computer.
{DDR2 Sdram at 400MHz = PC2-3200
DDR2 Sdram at 533MHz = PC2-4200 (Also known as PC2-4300)
Regards,
joecoolvette
Sep 18, 2011 | Computers & Internet
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
Installing 1 gig of memopry in third slot - snaps on the end of the slots will not close. The first two slots are blue - the next two slots are black and the snaps on the end of the black slots are not...
make sure the largest memory module is in the slot closest to CPU then push down firmly each end of the ram module
as for the notches the one with one notch is ddr ram the one with 2 notches sdram make sure that the module you are trying to install matches the slots and some brands are not combatible with other brands
good luck
Aug 27, 2010 | HP Pavilion a1540n PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
Memory
no it does not support ddr2 ram.
goto this link for mor ingormation.
http://support.gateway.com/s/PC/R/3724/4365sp3.shtml
good luck
Jul 09, 2008 | Gateway 504GR PC Desktop
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Ram slots
they are pairs for dual channel memory usage.
Sep 19, 2007 | HP Compaq dx2000 Microtower PC Desktop
Computers & Internet Logo
135 people viewed this question
Alun Cox
David Payne
David Payne
