What is this
With due respect
i have hp 530 with vista home premium preinstalled.now i want to install xp,but following msg occurs
"Setup didnot find any hard disk drivers installed in your computer
Make sure any harddisk drivers are powered on and properly connected to your computer,and that any disk related hardware configuration is correct.This may involve running a manufacturer-supplies diagnostic or setup program.
Setup cannot continue.To quit setup press F3"
now somebody say to me that i have to formatt harddisk.But if XP Setup is going on ,then how can i format harddisk,because i thing i can format with xp cd.i dont have floppy drive
  • Anonymous Jul 02, 2008
  • 58 Answers
If you are doing a clean XP install the CD will ask if you if you want to change your partitions.Afterwards it will automatically format the hard drive.Some of the OS discs dont come with drivers you will have to hunt for them on the internet.If you are using a restore disc copyied from a working machine it should have generic drivers already loaded in the disc.
Posted on Mar 25, 2008
SOURCE:
Hey how do i change from windows vista 2 windows xp can any tell me how plz need help
you cant install a older version of windows if the computer came from the shop with vista preinstalled, if it had xp previously and vista was install over xp then you will be able to
Oct 29, 2009 | Microsoft Windows Vista Home Premium with...
Sata
yes you'll have to format the drive before you put xp on...you can use a boot disk with something like fdisk on it...you can boot using a HIREN boot disk (which has FDISK on it) or Roadstarter which is a bootable CD with a whole host of utilities including FDISK.....
or boot with a windows XP disk and choose the repair with console option ...at the command prompt type in FDISK and you will wipe all the data and partition tables ....giving you a raw data drive to install Win XP to
Dec 22, 2008 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
Upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
Nov 12, 2008 | HP Pavilion dv6000z Notebook
How to install xp on hp 530
You can try to change in bios show HD as ide native or something like that. If u install xp it gonna destroy your vista installation.
Jul 16, 2008 | Computers & Internet
Problem
Your harddrive is probably S-ATA and xp doesnt have a build in driver for it. You need to download a S-ata driver from hps website, I'm not sure if xp can read the driver from anywhere else but a floppy. So i that case your going to need to buy a USB floppy drive.
http://www.hexus.net/content/item.php?item=1420
Theres a tutorial on how to make the floppy.
If the floppy doesnt work, you might need to copy all the xp files into the hard drive and add the Sata driver into the xp installer, that can be hard todo maybe il give you instructions on that later.
Mar 12, 2008 | HP Pavilion dv1000 Notebook
Sata
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Mar 12, 2008 | Computers & Internet
Driver problem
you need to follow these instructions:
0. Download the XP Sata driver from the support page and create the driver floppy, attached usb floppy drive to laptop: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=
en&cc=us&prodTypeId=321957&prodSeriesId=3375953&swItem=ob-51454-1&prod
NameId=3375995&swEnvOID=1093&swLang=8&taskId=135&mode=4&idx=1
1. Power up, hit F10 to enter setup
2. DISABLE SATA native mode
3. Follow the installation instructions in the supplied readme.
If you DO NOT disable native mode for the sata drive, you will end up going around in circles with the XP setup informing you there is no hdd in the laptop, even though you specifically installed sata drivers off the floppy.
Once you get past the "Hit enter to install Windows", you can trash all the partitions on the drive, and recreate one big partition for XP :)
***NOTE*** MAKE SURE YOU HAVE ALL OF YOUR DRIVERS FOR XP ON A CD AND READY TO INSTALL. YOU CAN DOWNLOAD THEM AT THE HP WEBSITE.
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
166 people viewed this question
Ekse
Alun Cox
