Plug the colored wires in the colored sockets, then plug the power cord into a power outlet, these are often found on a wall. And don't forget you must also plug the power cord ON the ps3. Then open the tv, either by using the remote or also you can open it using the button on the tv. Then you open the ps3 and switch the input channel on your television until you see the ps3 display. After that pick up a wired controller, be sure it is wired if not it won't work. For the final step use the wire of the controller and wrap it around your neck. You will then proceed to pull as hard as you can for as long as you can, until you die.
