Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
Interior rear vision mirror
I tried to move the mirror so i could see and the whole mirror came off it looks like it has just come loose but ive tried and tried to get it back on and it wont work can someone help me i just borrowed the car off my dad
  • 26 Answers
Use 2 part epoxy. any parts or hardware store has it. in five minutes you will have your mirror back on looking for cops.
Posted on May 09, 2008
    Problem Solver:
  • 51 Answers
Please check www.playpower.com.cn
Posted on Mar 18, 2008
2009 Suzuki Burgman 650 Executive left mirror loose
Hi, Glyn for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://burgmanusa.com/forums/15-burgman-650/83225-loose-mirror-head.html
650 Burgman mirror
Suzuki AN650 Service Manual
OEM parts for Suzuki
http://www.motorscooterguide.net/Suzuki/Burgman650/Burgman650.html
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 02, 2017 | 2009 Suzuki Burgman 650 Executive
Replace rear vision mirror passenger side mazda 323 astina 2002
on the inside of the door above the door panel hinge side is a plastic cover almost triangle shape use flat screw driver to carefully pry off and the mirror mounting bolts will then be accessable
Jul 23, 2016 | Mazda 323 Cars & Trucks
How do I reattach the interior rear vision mirror on Toyota 98 corolla
If the rear view mirror mount has seperated from the windshield you can buy the glue kit at most auto parts stores. Any windshield installation company will also install it for a small fee.
Jul 09, 2015 | Toyota Cars & Trucks
My 2000 chevy suburban interior rear view mirror is loose at the adjustment section it drops down and seems loose to the touch when trying to move it up but secure at the section that is attached to the...
If you are referring to the mirror mount on tne windshield..there is a small hex screw on tne underside of tne mount that tightens the mirror to tne mount..just find the size very small and tighten it..ask at any of the auto parts stores..the screws are pretty much the same..Good luck...
Mar 04, 2015 | Cars & Trucks
How do i re move rear view mirror from 2004 325ci bmw a3ear view
should be a set screw look on bottom or side might have to remove arm with unit
Jan 26, 2013 | 325Ci Rearview mirror, manual / led....
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
How hard is it to replace the passenger side mirror on my Pacifica
not too hard, behind the mirror on the inside there should be a triangular plastic cover, this will unclip with a little bit of levering with a screwdriver or flat blade.
once removed you should see a few holes in the door frame, in a few of those holes you will see at least 3 bolt heads, undo the bolts making sure you dont drop them inside the door cavity, there will also be a multi wire electric plug that you will have to seperate, the outside mirror can now be removed.
Dont try just replacing the glass as it involves almost destroying the whole mirror assembly, replace the complete mirror assembly
Jul 03, 2010 | 2004 Chrysler Pacifica
My GMC sierra side mirror is loose on from the amr. The mirros is fine it is the little swivel that is looses and the mirror constantly moves. I am unable to remove the mirror to get to the problem.
I just spent about 2 hours trying to resolve the same problem, and discovered that there doesn't appear to be any way to repair the mirror without purchasing a whole new one. There a 3 screws you can access by slanting the mirror to the extemes in both the up or down positions. Once they are removed I discovered a 4th screw (once I broke the plastic pieces surrounding the mirror appart) that there is a 4th screw that is impossible to reach without removing the actual mirror part. In any case I discovered that the reason that the mirror was floppy is because there was a funny looking nut that is supposed to lock in the spring mechanism that was completely stipped and non functional. Better luck than me!
Sep 27, 2009 | 2000 GMC Sierra
2004 vw beetle conv interior rear view mirror is loose
No, the mirror is just a friction fit. You will need a new mirror.
Sep 17, 2009 | Volkswagen New Jetta Cars & Trucks
Loose Door Mirror
you may have to take the small panel off on the inside of the window oppersite the mirror it should prye off, then tighten nuts
Nov 13, 2008 | 2001 Jaguar XJ8
Car Audio & Video Logo
130 people viewed this question
Top XO Vision Car Audio & Video Experts
Marvin
Marvin
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
