Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programing garage door opener remote
I need help programing my garage door opener remotes i dont have the instuctions and i dont know what button is what other than the one that opens the doors. i have a craftsman 13953681b (model #). i have 2 doors and a total of 4 remotes. one remote will open both doors, the others will open one and close the others. but if you push any button more than one time they will all do something different. so i am going crazy... please help
crystal
  • Anonymous May 11, 2010
    I can help you with that pretty easy but I need to know how old your opener is apox, less then 10 years?
  • Anonymous Mar 29, 2014
    vehicle remote door opener wont program for craftsman garage door
    Novelist:
  • 91 Answers
Ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 504 Answers
START BY CLEARING ALL THE CODES ON BOTH DOORS. - HOLD DOWN THE SQUARE PROGRAM BUTTON ON THE POWERHEAD FOR ABOUT 30 SECONDS.
NOW PROGRAM 1 BUTTON ON A REMOTE TO DOOR #1 IF YOU HAVE 3 BUTTON REMOTES YOU CAN PROGRAM ANOTHER BUTTON TO THE OTHER DOOR.
YOU CANNOT PROGRAM MORE THAN 4 REMOTES PER OPENER
HOPE THIS IS HELPFULL
Posted on May 23, 2010
SOURCE:
I just installed a new rolling code chamberlain garage door. it works fine, however my other garage door opener is a much older sears.
the remote can use only 1 button to open and close if programmed right
open the lid of the seers control box and press the program button then use a different button on the remote to open and close
It would appear that the seers unit is also made by chamberlain
Jun 30, 2018 | Building Materials
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
May 21, 2016 | Building Materials
Programming remote and in car garage door openers to the Craftsman AssureLink Garage Door opener - Model - 139.3043
The opener radio is not compatible with your homelink system. You need to buy a homelink repeater. Note: liftmaster and chaimberlain are the same, so if you see a reference to one of those names when searching for the repeater, dont worry, it'll work. As far as the second remote, check batteries. Then try programing again, using yellow button on the opener. Lastly, you can reset the programming and start over if all else fails. Hold down yellow button until light on button turns off. Good luck.
Nov 02, 2014 | Craftsman AssureLink Garage Door Opener...
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Remote door opener
So, you get out your remote control to your garage door opener and, then get your owners manual to your new car. You need to follow the instructions from the manufacturer to be able to program the remote control to the car.
Ok, you have followed the instructions from the car manufacturer and you press the button for the garage door to go up.......and nothing happens. So, then you think you have missed a step on the programing. Well, what most instruction manuals leave out is the step from programing the car/truck/van to the garage door machine itself. On the back side of your garage door opener is a panel called the logic board. The logic board is the computer or brain of the machine. Most new garage door openers now are a mulit-code machine. By that, i mean it uses several signals each time you press the button on your remote control. This is for security, so your code can't be stolen by a code-grabber.
Now, comes the step of programing the vehicle to your garage door opener. Once you have followed the instructions of programing your vehicle, you now have to "teach" the car to the garage door opener. You will need some help doing this. You will have to get someone to press the button in your vehicle and hold it down, while someone else has to press the learn button on the back your your garage door opener mounted on the ceiling. The learn button on the back of your machine will be square if using a liftmaster machine. Craftsman, Liftmaster, Chamberlain are all the same. Their learn buttons are square, and usually are yellow, red/orange, or purple. If using a Genie, it has a button that says "learn button".
The person pushing the button on the machine will only have to push and release the learn button. DO NOT hold this button down. If you do, it erases all of the programing in the machine, and you have to re-program all the remote controls that you have. You will have to read my other hub to find out how to do that. You will probably say a few words you shouldn't either. :-) Programing the vehicle to the machine only takes a second, and when the machine accepts the code, the light bulb on the machine should flash for a brief moment, and you should hear audible click. Yep, it's that easy! I dont know why the auto makers leave that step out. Anyway, i hope this helps, and if you have any questions.. leave them in my comments and i will try to walk you through it. See the photo above and you will see the typical logic board...the square red/orange learn button is easy to see. Just remember to press and release
May 08, 2012 | 1995 Lincoln Town Car
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
How can I program a craftsman remote for my door
THE OTHER BUTTONS ARE FOR ADDITIONAL DOORS.
CHECK THE FREQ. (FREQUENCY) IF YOUR NEW REMOTE IS NOT THE SAME FREQ. IT WILL NOT WORK - YOU WILL NEED TO GET ONE THAT HAS THE SAME FREQ.. - THEY ARE AVAILABLE FROM YOU LOCAL GARAGE DOOR DEALER.
HOPE THIS HELPS
NOTE: THE FREQ. IS ON THE BACK OF THE REMOTE AND NEAR THE PROGRAM BUTTON ON THE POWERHEAD - THEY CHANGED FREQ A COUPLE OF YEARS AGO.
Apr 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Setting garage door opener
Most openers are programmed the same. You normally program the house garage opener to accept the new remote. Your garage opener will have a button to press to add in a new remote. Normally you press this and then press the remote in the car and hold until your lights on your opener flash or the garage door closes. (check your manual on your garage door opener)
Mar 27, 2009 | 2005 Chevrolet TrailBlazer
Craftsman garage door remotes
push once the red button on the back, and then push the transmitter button u want to program u should hear 2 clicks inside the unit.. and if u dont.. hold down ur transimitter button .. the led in the back of ur unit should be blinking... otherwise let me know
Jan 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,736 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
