I just changed batteries but it keeps telling me that batteries are critical
  • prieto642 Mar 12, 2008
    I left the batteries on all night but it still keeps telling me that batteries are critical. What else should I do?
    Thanks.
    Sergeant:
  • 349 Answers
It may need time to charge the battery up ,so leave the pc on for a couple of hours to charge it
good luck
Terry
Posted on Mar 12, 2008
  • Anonymous Mar 12, 2008
    ensure the battery holds power before you put it in the board,
    is the cmos holding info ,
    ie do you need to :
    1) go into the bios every time you boot up, or
    2) do you need to set the time & date on boot up
    if you donot the battery is holding some charge
    you may be able to go into the bios and turn off the battery warning, but i am not sure about that.
    failing that ,if the batteries you have used are good then maybe a Bios update will fix the problem
    good luck with that
    Terry
    if my comments are worthy please rate them
SOURCE:
My Acer Laptop battery shuts down completely at 40 - 30
Go to Power Options --> On the plan you are using select change plan settings --> Change advanced power settings --> Scroll down till you reach battery and click the + next to it to expand the settings --> Where it says Critical battery level and Critical battery action (on battery) make sure that the level is at 5% and the action is to hibernate. If it's set to do nothing, it will keep running until it's out of battery and completely shut off. Plugging the AC adapter would give it more power. If that isn't the problem, check your battery's connection and consider replacing the battery.
Nov 03, 2012 | Acer Aspire 5742G
My watch loses 2-3 minutes a day even with a new battery. Is there an adjustment I can do?
No unfortunately there is not! you have gone as far as you can go by changing the battery. The problem lies in the timing module that houses the quartz crystal, it vibrates at a certain frequency that is critical for keeping time. This will require a jeweler who specializes in this type of repair to address the situation.
Feb 18, 2011 | Elgin Watches
If I did not charge my palm m515 will it still work? I just got a Palm m515 and I did not charge it for 24 hours before syncing it to the computer. It works fine on the cradle, but it will not keep a...
the m515 uses a Lithium battery .. the modern version of those batteries have a built in safety feature .. once its first activated then it monitors its own voltage .. if the voltage is ever allowed to go below a certain value then it will refuse to accept a charge ... when it tells you that the battery is dead its actually well above that critical voltage .. but if you let it sit for a long time then self discharge can bring it below the critical value .. when the battery is in that forbiden region then there is a chance that it will grow copper links through its insulator .. then when you try to charge it it could get very hot .. even explode .. so thats why the safety feature .. there are ways to jump start the battery and some people do that .. but you can see there is some risk .. the battery in that palm is not hard to change and they are not expensive but you need a very small torques driver to get the case apart .. i just took my 515 to the hardware and had them match it up with the proper tool .. there are kits available also that have a new battery and the proper tools to take the m515 apart .. of course they cost more..
make sure you have the external charger hooked up to the cradle .. it wont charge from the USB port voltage as i recall on this model..
Sep 04, 2009 | Palm m515 Handheld
Why does my mouse keep saying battery critical
you must use alkaline batteries not heavy duty to achieve the most current for any electronics products
Jun 09, 2009 | Computers & Internet
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
W300i
dear,
it can be defactive battery problem. did u try by changing new battery.
if not, do it by the way.
or if it not the issue then tell me that this problem comes automatically or when u open its flip to get viewed inside.
i had it and was facing white screen problem then critically invisible display. finally, i got strip problem becoz this kind of phones have it.
regards,
Dec 29, 2008 | Sony Ericsson W300 Cellular Phone
Pc is telling me to plud it in when the battery is at 90%
Your power settings may be set up to inform you at 90% the battery is getting low.
Windows XP
Go to control panel, Performance and Maintaince(only in catigory view), Power Settings click Alarms tab and adjust the sliders to the desired.
Windows Vista
Go to control panel, click change battery settings, find the option selected click the link below it saying Change Plan Settings, click the link change advanced power settings, go to the battery section and adjust the low battery level and critical level.
Dec 07, 2008 | Acer Aspire 3680 Laptop
Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Dec 04, 2008 | HP Compaq nx9020 Notebook
Changing the batteries
I'll give you info on how to change batteries in two different type mouse units. Not sure what type you have.
The normal way to change batteries on a mouse is to turn it over and open the little door on the bottom The compartment holds 2 AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 16, 2008 | Logitech 931150 Mouse
"Critical Battery Error" even with not battery in laptop
Do you have another power supply to use?
Also, is it keeping correct time and date?
Dec 14, 2007 | IBM ThinkPad T20 2647 Notebook
Open Questions:
Computers & Internet Logo
22 people viewed this question
Ekse
Alun Cox
