Question about Canon LaserCLASS Fax 710 Printer
Canon 710 fax machine
I am trying to figure out why my Canon 710 fax machine has suddenly stopped printing a TX report each day. We don't have a manuel and when I hit the reports button, nothing happens.
    Scholar:
  • 130 Answers
Reset the machine to print reports. If it continues not to try reseting the circuits from the panel.
Posted on Jun 11, 2008
SOURCE:
Hello - We have a Canon Model 3175MS Fax Machine - we want to print a comfirmation that a Fax has been sent. Is this possible? Thanks! Marcy
Yes, it is called a `transmission report' (TX report), and is a setup option.
You can change this setting with the following procedure:
Open the 1-touch panel to access the function keys.
Press the `data registration' key to access the user menu.
You should see `user settings'. Press the `set' key. Press the cursor down key to get to `report settings', and press the `set' key. You should see `TX report'. Press the `set' key. Cursor down till you see `output yes'. Press the set key.
Press the `stop' key to return to the normal screen.
It is now set to print a report after each transmission.
Oct 07, 2010 | Canon LC-3175 Laser Fax
How do I print a confiramtion page to make sure my
Press Funktion and then report-activity reports will be displayed press ok.Or you can go to funktion-datarigestration-scroll to reports,press ok,select TX report,select output yes.Then after you send a fax a tx report of the fax you send will be printed out.
Dec 08, 2009 | Canon FaxPhone L75 Plain Paper Laser
Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Sep 09, 2009 | Canon Office Equipment & Supplies
Need instructions on customizing Transmission Verification Report
Terry,
Please send me your email address...I can send you the Facsimile Guide in PDF formatt pages 11-11 and 11-12 provide Tx Report Settings.
[email protected]
Jun 03, 2009 | Canon Laser Class 8500 Printer
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jeff
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon FaxPhone L80
Press Function, Data Registration, and then Set. Use the up/down arrows to select "report settings", then Set again. Using the arrows and Set change the values or TX REPORT and RX REPORT to "YES". This will pring a TX/RX report after every fax. When you are done press Stop/Clear. This is from Sectioon 14 of the owners manual. Let me know if you need more help.... [email protected]
Aug 20, 2007 | Canon FAXPHONE L80 Laser
Print Report for Specific Date
I haven't found a way to print a TX report for a specific date. However there is a way to set the machine to generate an activity report at a certain time each day. Press "MENU" , 2-4-2, and you should be able to select the interval for your report by pressing the "OR" key (24 HOURS in this case). Hit "MENU" again and then enter the time you wish the report to print (24 hr format). "MENU", "STOP" and that should give you a report you can use each day.
Apr 23, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon LaserCLASS Fax 710 Printer Logo
315 people viewed this question
Clive
Clive
old marine
old marine
Ekse
