Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Hotpoint ultima 1200 (by 2 users)
posted by kirsty mac on Mar 12, 2008
my wasing machine is loading with water but its not drainig ive checked all pipes none are blocked ive checked the filter nothing there either .my black drainage pip is not blocked either. on screen yesterday before checking pipes it was saying cheek water supply e11 after removing pipes etc it is still the same but cheek water supply e10? i have no manual and failed on internet looking for one please help me!!!!!!!!!!!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 10, 2008
water is not draining out
Solution #1
posted on Mar 16, 2008
Not Rated (0)
TAGTEL
Rank:Master Master
Rating: 97%, 26 votes
Kirsty - There could be an item like a hair clip Jamming the pump impeller. Or then it can be only a blockage in the filter or in the waste pipe or if the waste is connected to your sink drain check that the blockage is not there - either in the end of the pipe or in the sink connection.
Try disconnecting at the sink, holding the waste pipe into a bucket see if it will pump out then. If it does then the problem lies in the sink plumbing - if not then it lies in the machine.
If the pump and filter and hoses are definitely clear you could have a Pump, PCB or wiring fault. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hotpoint ultima 1200:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
hi. I have fisher & Payakal top loader washing...
Washing Machines
Hello, my Fisher & Paykel Smart Drive 703, has just...
Washing Machines
where can you find in australia, a catch for a door of...
Washing Machines
I own a sears kenmore washer with no cold water flow, i...
Washing Machines
The bottom part of the agitator works fine, but the top...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
