Question about Ricoh Aficio AP3800C Laser Printer
Savin C3030 I have a Savin C3030 and its giving me the error code SC553. Should I replace the infuser unit first and if that doesnt fix it what is next?
  • 87 Answers
SC 553 is a fuser overheat error. If you have a fuser great, but you will still have to reset the code. Clear modes, 1, 0 ,7, press and hold clear/stop key. Menu will change, select copy sp. From there, select 5, (mode), scroll till you get to 5810. Select it, and press execute, then exit back to copy sp. Select 7 (data log) then scroll until you get to 7807. Select it, and press execute. Exit all of the way out, and recycle the power.
If it comes to ready, great. Try it. If it codes out again, you have a problem, possibly thermisters, (in the fuser), power supply getting stuck on, I/O board not regulating the power supply. Could be any of these things.
But start by resetting the code. Could be a a thermister got some toner stuck under it, and the other thermister detected a difference. It really could be that easy.
Posted on Mar 12, 2008
Error code sc553
lower pressure roller heating problem replace fuser assy and reset code or have tech come out
Apr 02, 2013 | Ricoh Toner for Aficio MPC2800, MPC3300,...
Im getting magenta backround on all color copies. I replaced the drum and developer, this did not change the problem
I had the same issue. I removed all the drums and DV units, removed the transfer belt and open the manual infrrd door and pulled to fuser. I found huge piles of magenta tone all over the place. Cleaned it up, put it back together and runs like a champ
Feb 08, 2013 | Savin Transfer Belt for C4540, C3535,...
Savin C3030 copier. refilled staples, but copier thinks empty. How can I get the copier to sense the staple refill?
There is a sensor that tells the machine if there are staples present. Check to see if it has been moved out of position or if the wire going in has been broke or crimped
Mar 29, 2012 | Savin 8035e Copier
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
Touch pad control panel on Savin c3030 doesn't work - the rest of the control panel buttons do just not the touch pad for any function?
Hello.I can ASSURE you absolutely what the problem is.Your Savin copier(which is a perfectly fine device) is actaully manufactured by Ricoh.I work for a Savin dealership and Ricoh contacted all dealers WORLDWIDE with the news that due to a manufacturing defect that the touch screens of al models such as yours WILL fail.They sent out free of charge replacement touchscreens to all dealers as they have a record of how many of what type was sold by whom.I mean we had a crate of touchscreens show up at our dock at about the same time we started to get a barrage of service calls for this problem. It was one of the wildest things I've seen.Now it is just the "glass" of the touchscreen that is defective as it actually an "active" part of the op panel's circuitry of the op panel.It is relatively easy to replace.Now the question is, how do YOU aquire one,as it is a known defect and is covered by warrranty.I have to assume you purchased this device on your own and that you do not have a service agreement thru an independent dealer.My advice would be to contact whomever you bought the device from or perhaps Ricoh directly and tell them the problem and that you are aware that Ricoh is aware of the problem and see what they say.I cant tell you how many of these things I have had to replace as it is not a matter of IF there will be a problem with the Savin c3030 touchsreen, but merely when.Good luck, and although I did not "FIXYA" I hope you will acknowledge to the sight that I gave you the facts that you need. :-) Take care
Jun 22, 2010 | Savin Office Equipment & Supplies
New internet service now Savin C3030 won't work
Reinstall the printer on your operating system. For example, Windows XP is probably still trying to print to the old IP address. You will need to find out the new IP address of the printer and tell your operating system to print to that new ip address.
Mar 06, 2009 | Computers & Internet
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
Error Code SC553
You are definitely on the right trail, here is what is is. Pressure roller fusing lamp over heat
The detected pressure roller temperature stays at 200°C or more for five seconds. It could be:
• Defective PSU
• Defective BCU
You did the first thing, you will need to try the other two.
1. Replace the fusing unit.
2. Replace the PSU.
3. Replace the BCU.
Remeber the BCU is next to the controller.
Jan 28, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
846 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
