Question about Kenmore 98702 Stacked Washer/Dryer
Dryer takes forever
I have a stacked washer/dryer...the washer is perfect. It takes a whole day to dry 3-4 towels or a small load of clothes. Dryer does heat up, but it's taking too long to dry clothes. Please help.
  • 3 more comments
  • gandj Mar 22, 2008
    Same problem, and we think that lint clogging the back is the problem.  We've taken almost the whole dryer apart and have been able to get rid of a great deal of lint.  But we can't figure out how to get the back off. Any suggestions?
  • Anonymous Apr 08, 2008
    I changed the heat element and temp switch still no heat what can i do
  • stauf Apr 24, 2008
    I am also having a problem with clothes taking forever to dry. I have cleaned out the exhaust vent from the inside of the house to the outside and checked the exhaust vent from the dryer to the wall vent. The dryer is less than a year old and had worked great before we moved. When we moved, I had to change the pigtail to a three prong instead of the four prong. Would that make a difference? I wouldn't think the thermostat would be bad, would it? Any suggestions would be helpful. My email is [email protected] Thank you
  • skr34m3r Apr 30, 2008
    The washer works great, but the dryer just tumbles. I have to dry a
    half load of clothes for 3 cycles before they come out dry. It gets
    slightly warm after the second cycle. I checked the circuit breaker and
    voltages and all are ok. The vent is positioned straight out with 1.5
    feet in between the dryer and the exit hole. All spaces within the vents have been thoroughly cleaned. Any suggestions will be
    helpful. Thanks.
  • Anonymous Mar 28, 2014
    GE dryer model DS4500EA1WW, heats up, but clothes don't dry
    Novelist:
  • 131 Answers
You have a clog somewhere in the venting. Anywhere between the lint screen and the outside of the house. Use a vaccum with a crevice tool to reach behind the lint screen. Also check the flaps on the outside of the house. You can also access the machine end of the vent pipe by removing the two Phillips screws on the angled panel just below the dryer door. If you feel you need to take apart the machine further to clean behind the lint screen, write back. It's very tricky, and will take some time, but I can walk you through it.
Posted on Mar 12, 2008
SOURCE:
Dryer takes forever to dry clothes
Check out this tip... it will help you to find out what is making it take so long..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Maytag PYE2300AY Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Wet towels & blankets stacked on working dryer
This won't affect drying time unless the load is so heavy it causes the cabinet to warp and disturb the door seal. If you haven't had any problem with this so far you can probably keep doing it. (The machine is designed to support the weight of a wet load in the drum, and should have some safety margin. But why not invest in a roll-around laundry cart like you find at laundromats and keep the wet load there until the dryer is clear?) You might need to be more concerned about rust starting on the top of the cabinet if the enamel is scratched, since it's not usually subjected to wet loads being piled there. You should also check your vent pipe frequently to make sure it stays clear with all the drying you do. Clogged lint screens and vent pipes will definitely lengthen drying time.
Feb 18, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
117 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
