Question about Creative Labs Zen Nano Plus MP3 Player
Power won't stay on more than 10 seconds even with fresh battery
    Problem Solver:
  • 9 Answers
Not sure how this helps, but mine does the same thing - shuts off somewhere in the startup sequence, sometimes makes it to a music track, then shuts off, etc. I have actually sat and continually pressed the power button to see if it cleared up - voila'.. after about 15 power cycles, it stayed on.. Will post back here if there's any "better" solutions. (I am searching for a better answer myself.)
Posted on Mar 27, 2010
SOURCE:
When i put the key in ignition it has power but when i go to start it nothing happens, not even a click.
Sounds like either the battery has insufficient power to turn the engine over, or solenoid is stuck the starter motor. A quick check for the battery condition is to turn the headlights on for 10 seconds. If they dim very quickly or do not come on at all, then the battery will need a trickle charge. Check the battery indicator if one fitted or remove the tops from the chambers. Please be careful when removing these as battery contain acid and can be very corrosive, depending on battery condition. If headlights stay on for more than 10 seconds suspect solenoid being stuck.
Good luck. S
Jan 12, 2016 | 2001 Mitsubishi Montero Sport 4WD
Car has brand new battery and won't even crank
Sounds like a poor connection somewhere,bad alternator(not charging the battery) or a simple relay
Jan 23, 2013 | 2008 Mercury Milan
My vivaz won't come on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 19, 2012 | Sony Ericsson Vivaz Cell Phone
My phone won't turn on
5.Wait 10 seconds.
Step
Thanks
Sep 14, 2012 | Apple iPhone 4 Black Smartphone
My Nokia e52 won`t start
5.Wait 10 seconds.
Step
Thanks
Aug 16, 2012 | Nokia E52 Smartphone
5.Wait 10 seconds.
Step
Thanks
Aug 03, 2012 | Cell Phones
My dell inspiron 1545 won't start, I have pressed
removed your battery and charger then hold the power button for at least 10 seconds then replaced battery and charger.. good luck
Apr 08, 2012 | Dell Computers & Internet
My anti theft system has activated and shut down the electronics in my car. Now my car won't start or even turn on. What do I need to do?
You could try to reset the main computer by disconnecting the power cable from the battery press on the brake for 10 seconds then return the power cable to the battery
Good luck !
let me know how it turns out
Sep 09, 2011 | 2006 Pontiac Grand Prix
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
Aug 27, 2017 | 1998 Jeep Grand Cherokee
Help on P72
The recycle time using flash gets worse pretty quickly if you are using the onboard flash. The delay is pretty much inversly proportional to the remaining charge in the battery. I.E. the less charge, the longer the time. This happens with any camera. You might check the time with fresh batteries (or freshly charged) and then after maybe 20 shots or so. I would not find 5 seconds atypical, but 10 seconds sounds like you are pretty close to dead battery. If you get 10 seconds at the start of a fresh battery, then you may have a problem. Also, capacitor charge time can vary from capacitor to capacitor and a 1-2 second variation between camera flash units, either onboard or off board is probably normal. Age of capacitor can also have an effect.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Creative Labs Zen Nano Plus MP3 Player Logo
82 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
