Question about Krups XP4030 Espresso Machine
No water flow even though descaling
The machine won't pump put any water, either from the head or the steam nozzle, no water comes out into drip tray either. I have tried descaling but cannot get water through with this process either. It makes all the sounds it should do however.
  • Anonymous Jun 16, 2008
    the orange light wont go off and the drip tray fills up with water
  • stugots Jun 16, 2008
    the orange light wont go off and the drip tray fills with water
I KEEP having this problem... everything is in place, but no espresso. Nothing comes out the brew head. I have found multiple fixers for it. One: make sure you have water in the tank and that the tank is firmly pressed down (this was the most embarrassing of the mistakes I made), Two: try a slightly courser grind of espresso. On my Black & Decker burr mill, I have it on the 3 (of 12) to finest settings. Tamper only a little bit... not too hard. Three: when the flow is just not happening, try running some steam through the nozzle to see if you can get things moving along. Once I ran the steam through... it sputtered and coughed for a few seconds then steamed normally, then cooled it back down and the espresso came out fine. This was the most recent fix.
Posted on Dec 07, 2009
This may sound like a silly solution, but this happens to me a lot too, and this is how I fix it.
Just check the water container. Lift it up, and put it back down. Then, make sure it is really locked in, so press it down some more.
I know this sounds ridiculous, but the same thing happens to me ALL the time.
Hope this helps.
Posted on Sep 14, 2008
I started the descaling process as according to manual. I tried running water through every 6 hours or so, however it kept coming up dry. I left the water in for a total of 2 days before finally the water managed to come through.
Posted on Mar 14, 2008
    New Friend:
    Problem Solver:
  • 7 Answers
You can try this different approach: open up the back of the appliance, and blow hard into the rubber hose that comes out of the water reservoir and into the pump, _while_ the machine is on and in espresso mode. The machine starts coughing, then water flows. You might have to fill the pump hose with a little bit of water.
Posted on Feb 02, 2013
  • Ricardo Fabbri Feb 02, 2013
    dont forget to descale after you get the water through - the machine will likely clog again in a few days
SOURCE:
Xp 9000 stuck in descaling process
Do you hear the pump running? Is it possible that the pump has ceased to function?
Aug 25, 2014 | Krups Coffee Makers & Espresso Machines
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
No Steam
Unit sounds like the steam valve and orings have failed.
This causes no steam and internal leakage.
Sep 10, 2008 | Gaggia Titanium Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Krups XP4030 Espresso Machine Logo
2,666 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
