Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson 1000 watt microwave
Only bought this 8 mos ago. I shut door on it & It had a quick flash of light in the back, near top & just went dead - no power - nothing.
Do I take it back to store or what? It must be under warranty, but do I have to contact emerson?
Is it even worth fixing?
  • Anonymous Mar 15, 2008
    Its the stupid fuse. I have had to change mine 3 times. I am going to the repair store now!!
  • 2,336 Answers
This appliance still under warranty, I would suggest to call the manufacturer and ask them for the nearest authorized service center.
Make sure you have the receipt where and when you bough it.
Good Luck.
Posted on Mar 12, 2008
Emerson microwave 1000 watt - how to tighten door on hinges
The tool is a special so nobody can tamper with the door, you need a repairman that is equipped with this item or see if you can get one from manufacture. The microwave leakage radiation is of concern especially in near range of the unit and should be corrected quickly.
Mar 27, 2012 | Emerson Microwave Ovens
My Danby Diplomat 1000 Watt microwave suddely stopped workinmg (display went dark, no door light, nothing). I'm thinking it could be a fuse?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 26, 2010 | Danby DMW1406 1000 Watts Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
Mw8115ssw no power
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Microwave completely dead
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Maytag MMV5165 Stainless Steel 1000 Watts...
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Nov 02, 2007 | Emerson MW8107WA Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
