Question about Vacuums
Vax 4100, how to disassemble for repair
I need to take apart a Vax 4100 to replace the bucket clip.
  • missiles32 Jul 14, 2008
    I need to disassemble VAX 5110 to replace bucket clip.
  • nasashah Nov 22, 2008
    I need to disassemble vax 4100 vacuum cleaner to see why the water from the bucket is not flowing into the brush. I do not know to disassemble it.
To disassemble a canister vax you first remove 2 screws holding the handle cover. One is just above where the power flex enters the handle, the other is at the mid-point of the top, hidden under the label. Both are small crosshead screws. Before doing attempting this, you need to be competent with working on mains electric wiring, as some of this has to be removed to do all this.
Once the handle covers are removed, the next bit is to gently lever off the speed control knob - it's a tight friction fit, then undo the nut holding it to the handle cover panel. After this undo the mains power connections from the multi-block joiner they go into then remove the 2 screws securing the mains wire. Then undo 2 bolts at each end of the handle going downwards into the main body. At this point the handle can be removed as well as the top body plate. You have to fiddle the electrics and switches through the hole in the top body plate to remove it. Now 3 bolts and a small crosshead screw is all that holds the upper motor section to the lower. Remove these and you can separate the 2 halves which gives you acess to the water pump. This is held in by screws founf underneath the plastic ring at the base of the motor body (around where the small reound blue sponge filter goes). This ring is held in by plastic springy clips. Gently lever round it to get it come off.
That's it. Re-assemble is reverse of all this. Don't disconnect the electrics without drawing pictures or photographing to work out which wire goes to where.
Posted on Mar 09, 2009
On the handle there is one small pozidrive screw, remove and orange panel comes away revealing powercable securing bar. Remove 2 screws and this reveals a 10mm headed bolt. Under label on top of handle there is another small pozzi screw, undo this and the handle cover can be removed revealing the other 10mm bolt which needs to be removed. The upper orange cowl can now be eased upwards and if you note where the 2 switches are located, they can be eased from the handle area by depressing the switch locating clips. This allows the upper cover to be put to one side with the power cable still threaded through. DO NOT REMOVE any of the connectors from the connections otherwise you might need a competent electrician to help you. At this point there are 3 similar 10mm bolts which, when removed, allow the bottom black plastic 'ring' to be removed from the orange plastic with the motor attached. You then should be able to replace the bucket clip. Hope this helps
Posted on Mar 19, 2009
My vax rapid carpet cleaner no suction filter is fine
If the vacuum is still functioning, the hose is most likely clogged. Disassemble the vax and unclog. Make sure you drain before disassembling. If possible do this outside.
May 16, 2016 | Filter Vacuums
Vax vacuum cleaner. Lead pulled out too far and now it won't switch on. Lead is retracting o.k.
Check the fuse in the plug 1st, but you may have ripped the wire/s from inside the hover out of there connector. If you are able to, you may be able to take the hoover apart and reconnect the wires, if you feel this is something you are not happy with doing you may be able to take it to a repair shop! If its still under warranty you may be able to take it back and get it replaced?
Feb 23, 2015 | VAX Appliances Vacuums
VAX CYINDER DEAD
Hi There, If you are talking about the Vax vacuums that are looking a bit like R2D2 (bucket on wheels) the most likely cause is a short in the power cord. It is easily fixed by shortening the cord by 30 cm. If you are not comfortable shortening an electrical lead any electrician or repair man will be able to do it for you. A second possible cause is a faulty switch. A distant third possible is the motor itself has failed.
The motor really should only be replaced by a technician unless you are very comfortable playing with this type of repair.
May 16, 2012 | Vacuums
HOW DO I TAKE APART vax performance 2200
I fixed a stuck mains cable on a VAX 2200 and made this take-apart guide. Use at your own risk. I hope it helps someone.
http://homepages.herts.ac.uk/~comqpq/VAX2200-takeapart.pdf
Jan 20, 2012 | Vacuums
When I switch off my Vax G3 cylinder cleaner it trips out the whole of the ring main circuit - I think the on/off switch is defective and wonder how much it would cost to repair and who - it is just over a...
Hello Lyra_cross, if your machine is in warranty please call the Vax Careline on 0844 4128 455, with your machine and receipt available, and an Advisor will be able to help you arrange a repair/replacement free of charge; if you do not have proof of purchase, Vax can provide a £60.00 repair service which includes collection by courier, inspection and then either repair or replacement and then return to you, again by courier, with a 12 month warranty.
The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team
Mar 13, 2010 | VAX Appliances Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
VAX HOOVER PROBLEM?
The 121 should only have the main filter ring taken out before the reservoir tank is put in which easily just falls into the main dust tank area. Make sure though that the bin's square edge is at the front where it rests at the front of the Vax where the hose comes out. Then unhook the pump to lay it in the water tank and the motor should be able to jam ontop clipping both sides down to lock. Perhaps you are putting the reservoir bucket in the wrong way.
Jan 12, 2009 | Vacuums
Roller brush on x5 chipping apart
Not too good, but there are motor problems with these models all the time. Personally I do not know it can be fixed without replacing 3/4 of the machine, which can be pricier than a new higher quality sweeper. I work for a repair shop/ dealer so if you need some assistance let me know.(570)326-1731
Feb 22, 2008 | VAX Appliances Vax X5 Bagless Upright...
Vax 6151sx water inlet tube
Have taken Vax to repair shop. Not easy to do at home, unless a qualified mechanic. The motor has to be taken apart.
Mauz
Feb 10, 2008 | VAX Appliances Vacuums
Vacuums Logo
2,191 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
