Water temperature Whilst in the process of having a shower, there was a power cut. Since then, my Triton Spellbind shower's temperature can only reach a max of 33 deg.C, which is far too cold in the mornings for showers. Has anyone encountered this problem before and if so, please help.
  • Michael Grimshaw May 11, 2010
    I just had to reply to anyone using the word 'Whilst!' I know nothing of the Triton Spellbind. Sorry, I've never seen one. Sounds like an electronic temperature control. If that's the case, bad things can sometimes happen if power is removed during normal operations.
    Novelist:
  • 131 Answers
Did you need to replace the entire unit?
Posted on Mar 17, 2008
Thanks for trying Bromikl. I'm actually surprised you didn't mention why I had logged this query in "washers" instead! And before you ask....there wasn't a topic headed 'Showers' so I picked the closest to it!!!
Hey! but if "Whilst" does it for you, I was glad to help!
Posted on Mar 12, 2008
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Triton caselona water temperature
Sorry to ask but are you gradually increasing the water temperature from cold to medium to hotter. Let it run a little while hot and cold mixes to give you your desired level. Also try cleaning the showerhead to remove any build ups (a maintenance issue).
Jul 15, 2013 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Jan 10, 2011 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Mar 22, 2009 | Home
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
Washing Machines Logo
224 people viewed this question
Top Washing Machines Experts
