Toshiba 1210 I have a flashing symbol on my display panel, it is of an arrow pointing to three rows of dots, in the form of one dot, then 2 dots , then 3 dots, all inside a square box. is this anything to do with the ink powder?
  • co nanny May 20, 2008
    I can't even figure out where to change the toner! Isn't there something that needs to be cleaned as well?
    Problem Solver:
  • 4 Answers
replace original donar catridge it will rectified,if you use refilled catridge the powder become overflow and then doner to be wasted,therefore use original doner catridge the problem rectified
Posted on Mar 12, 2008
Asus manuals
Not seen a manual as such but a dummy or similar guide to Android is likely to have one.
Most android keyboards including jellybean (4.2) are pretty standard.
The up arrow is shift for capitals and hold for a couple of seconds to get all caps rather than one and then return to lower case.
Bottom from right - ?123 is for numbers and symbols and it toggles.
The symbol next to it is for speaking commands rather than type.
long blank is the space bar, then dot,
Left arrow is carriage return or enter. Above this the x with white arrow is backspace delete. A multidot symbol toggles the keyboard on and off the screen.
Normally when you enter a field on a form the keyboard automatically appears. It also appears when you enter a browser address box etc.
Aug 07, 2014 | ASUS MeMO Pad FHD 10 ME302C-B1-BL 32 GB...
Flash not working
Can be for severe; reasons.
1. There is enough light.
2. You can force the flash, with the mode switch to Flash forced on, Slow synchro and Flash forced off. Try flash forced on.
3. The battery is not fully charged. When there is not enough power in the battery, the flash can't be charged enough to fire. But if the camera tries to charge the flash, a symbol with a lightening arrow and a dot is displayed. So if you see these symbols, could be you need better batteries. Try charging the battery.
4. the flash is really defect. Could happen too, but first check if everything from 1 to 3 is as it should be. only than you have to visit the repair shop or Sony if it is still in warranty.
Nov 30, 2013 | Sony Cybershot DSC-S950 Digital Camera
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
Timing chain
Each gear has an arrow and a dot. The chain should have two differently colored links. Position the crankshaft sprocket so the arrow is pointed up with the dot to your right. Position the camshaft sprocket with the arrow pointed straight down at the crankshaft sprocket and it's dot should also be to the right. The colored links on the chain should be lined up with the dots.
Apr 12, 2009 | 1996 Chrysler Town & Country
Can't change the decimal symbol on my Kensington 33006PocketKeyPa
You can customize this setting in the Regional and Language Options in the Control Panel for Windows,
Dec 26, 2008 | Kensington Pocket KeyPad (33006) Keyboard
Hp 1320 wont print
i think you might consider checking the toner on your printer, i.e. replace the cartridge...
hope this helps
Apr 09, 2008 | HP LaserJet 1320 Printer
Error Light
This is the add toner light. Replace the tube of toner and will be well.
Dec 28, 2007 | Canon NP 7130 Black and White Copier
Language
First you press the browse button, it's the round button in between the arrows, right above the number 2 keypad. Then you look for the picture of a screwdriver and wrench, press the right dot above the power key to select. Once it's selected, go down to the 6th row and select using the right dot. Then go down to the 6th row again which is the language option select it with the right dot. The search for English to change your language. That's it! Hope this helps! =)
Dec 25, 2007 | Motorola Mobility L6 Cellular Phone
100 people viewed this question
jasbo
jasbo
