Fridgidaire front loader washer/ problems with softner dispensor
Hello, i have the f. front loader, the pull out drawer, softner dispenser will not take the solution, i finish
with the wash cycle and there is the softner still contained in the holder, i have cleaned everything i know to clean. what more can i do??
  • dadl Apr 03, 2008
    I am having the same problem, however the fabric softener has been rinsed out and there is just standing water left in the dispenser when the load is through. What does this mean? I have to pour the water out each time to add any new fabric softener. Thanks!
    Novelist:
  • 131 Answers
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
Posted on Mar 12, 2008
Fabric softener won't empty out in my frigidare front loader
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Jan 24, 2011 | Washing Machines
Soap, bleach, softner dispenser not working
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
The frabic softner dispensor is not releasing the softner in the washer.
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
Electrolux front loader, softner dispenser doesn't empty
heatman101
Sep 02, 2010 | Electrolux Washing Machines
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet front loader is not draining. Water came pouring out of the soap and fabric softener dispenser. There was not a code displayed when this happened
make sure the drawer is closed all the way , and that you don't have a build up of soap in side where the dispensor drawer slides , this could keep the water from going into the washer.
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Washing Machines Logo
497 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
