Router: D-Link DI-524
Repeater: D-Link DWL-G710
I am trying to set up a repeater by getting into its web interface
to choose the SSID of the router, but am having problems. I am
directly connected (wired) to the repeater to access its config
pages. The repeater is 192.168.0.30 and I set a static address
on my laptop of 192.168.0.101 for the wired connection. I cannot
access the repeater if I have both the wired connection and the
client radio, or only the client radio, on at the same time.
So when it comes time to do the site survey on the repeater, I
tried plugging the client radio into the laptop but of course it
then loses connection to the repeater and cannot complete the
survey.
What can I do to get around this problem?
1 Other User Has The Same Problem
Comment by Guest, posted on May 10, 2008
Bekomme keine verbindung zum Fritz Media
Rating: 0%, 0 votes
to access the repeater via the router........
Robert....
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
1) Turn wireless card OFF ? It stays off during entire installation.
2) Open My Network Places
3) Right click ?Local Area Connection?
4) Click ?Properties? button
5) Scroll down to ?Internet Protocol (TCP / IP) - Highlight
6) Click ?Properties? button
7) Click ?Use the following IP address?
a. IP address = 192.168.0.50
b. Subnet Mask = 255.255.255.0
c. Leave all else empty
8) Click ?ok?
9) Click ?close?
10) Plug DWL G710 Extender to electrical outlet
11) Connect DWL G710 to computer with LAN cable
12) Open Web Browser (Leave wireless card OFF)
13) Type in http://192.168.0.30
a. This is the D-Link Extender?s default address
b. Click ?connect? when message says work offline or connect
c. You should see Login Screen for D-Link here
1. If not ? Ensure LAN has static address set to 192.168.0.50
2. It took 2 or 3 attempts to get login screen
** If you cannot get the login screen:
a. Click Start (from start menu)
b. Click ?Run?
c. Type ?Command?
d. Enter
e. Type ?ipconfig? to check LAN address ? confirm it is correct
f. Type ?ping 192.168.0.30?
g. If no reply or ?Request Timed Out? ? Reset D-Link Extender
1. Reset button on back of unit ? Use paper clip ? press for 10 seconds
2. Wait for lights to come back on and LAN connection to re-establish
3. Ping again ? when you see reply ? Go back to Step 12 ? Open web browser
4. I connected at this point.
14) When you get D-Link login screen:
a. Type admin in user line
b. Leave password blank ? Hit enter
c. Open ?Wireless? tab
1. Set wireless network to your router network
2. Use browser button to select proper network
d. Open ?Network? tab
1. Set network address to match Router network range
2. 192.168.X.30 (Number after 168 must match network number)
3. Whatever network address is ? duplicate but last number = 30
15) Finish setup wizard
16) Disconnect LAN cable from computer and D-Link Extender
17) Turn off LAN on computer and turn on wireless
18) Connect to D-Link Extender with wireless
Post a New problem for D-Link AirPlus G DWL-G710 Repeater
Email this problem
Can you Help with these Networking Repeaters problems?
can a dlink dwl g710 range...
D-Link DWL-G710 Vista LAN IP...
I have a dwk-700AP
DWLG710 problem
