Question about Cuisinart DCC-1200 Coffee Maker
DCC-1150 Coffee Maker does not have power
As usual, wanted to brew a morning pot and found the unit dead. No power what so ever in the display or lights. Outlet is very fine.
Unit is only 4 months old. As usual, wanted to brew a morning pot and found the unit dead. No power what so ever in the display or lights. Outlet is very fine.
  • Anonymous Apr 01, 2014
    unit only about 15 months old
  • 2,326 Answers
Talked to Cuisinart tech support and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults.
It looks like a thermal fuse might have blown inside your appliance.
If a thermal fuse has failed, there is probably another problem inside.
If the appliance is 4 months old, still cover under manufacturers warranty, Call the Cuisinart customer service to ask them where to find an authorized service center.
Hope this works for you.
Posted on Mar 12, 2008
  • 871 Answers
Can you check if there is a blown fuse there? kindly please check also the power cable because if the outlet is fine, power might not be going to your machine because of the faulty power cable.
was there any power shortage before your machine started like this?
    Master:
  • 788 Answers
First thing to consider if you are going to try to fix it is to leave it unplugged for 12-24 hours and try again. After that it is time to take it apart! Just try to get to the circuitry and look for burnt components, broken connections, or burnt fuses. It may be possible to repair by simply re-soldering something. If nothing seams out of place then it might be a burnt out IC which would be very hard to diagnose and replace. I would consider replacing the unit if it comes to that unfortunately. Good Luck!
    Master:
  • 351 Answers
Dear Aguilar123,
its the genral problem with this model of DCC-1150 Coffee Maker. to resolve this ,Try holding the on switch "on" until the light goes on.
i'm sure it will work.
Cheerup
WHY DOES MY COFFEE MAKER SHUT OFF
Theses types of home appliances are not repaired, they are considered disposable, replace it.
Jun 30, 2017 | Cuisinart DCC-1200 Coffee Maker
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
Leaks while brewing does not drain into pot fast enough
Usually you would need a new filter basket for that, which you can get from the manufacturer. However, I was just recently informed by someone w/ a very similar issue that running vinegar and water through the unit may help that as well. But if that doesn't work, definitely contact the manufacturer about getting a new brew basket (800-726-0190), because I've often found that it's the gasket within the spring mechanism at the bottom that is weakening and pinching shut when it heats up.
Aug 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
May 20, 2008 | Cuisinart DCC-1200 Coffee Maker
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
1,865 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
