Question about Dell All-in-One Printer 810 with 2-Year Advanced Exchange Service
Won't print My New Dell 810 Printer says there is not ink cartridge but I have put it in.The tape was removed and it is inserted correctly Please Help
I insert the new ink cartridge still it saying ing is low( its original)
Posted on Jan 30, 2009
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
Oct 09, 2011 | Dell 810 All-In-One InkJet Printer
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
Turn on your printer.
Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Any idea why all of a sudden my printer won't accept my ink cartridge? The power light keeps flashing and won't let me print. I have checked the cords, uninstalled and re-installed the printer and even...
I presume that your are replacing the ink cartridge with a new one. Although this may seem obvious, be sure that all removable tapes around the printer head have been removed. Sometimes this is not so obvious.
Oct 31, 2009 | Dell 810 All-In-One InkJet Printer
I installed a new print cartridge into my printer... after installing the new cartridge "install print cartridge" window prompt shows "unsupported cartridge" and instruct to install a correct print...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Dell 966 All in one printer
make sure sticker off ink as u put it in go download new drivers from dell.com for it they have big updates to fix that
Feb 21, 2008 | Dell 966 All-In-One InkJet Printer
Dell All-in-One Printer 810 with 2-Year Advanced Exchange Service Logo
100 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
