Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Green light blinks no turn on
I read to fix the problem is repleace 4 capacitors but i cant find them, cant you send me a picture?
  • Anonymous Apr 01, 2008
    Blinking green light syndrome! Mitusbishi ws-65513 won't turn on. Same as all the rest. All I need to know is where and how to get to the board, and I will take to professional to replace, along with the capacitors.
  • Josh Crager
    Josh Crager May 11, 2010
    Please send me this information as well!! Thank You soo much!!
    [email protected]
    President:
  • 3,130 Answers
Leave an e-mail address.
Posted on Mar 12, 2008
SOURCE:
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
A quick fix for this is to use a hair dryer to heat up the capacitors and then plug the tv back in.  It should only take about 90-120 seconds to heat them up depending on how hot the dryer is.  The cap's are located on the right side.  Take the front cover off the TV, and heat up the box that is about the size of a small cable box on the right side.  Once the cap's are warm, they will stay warm as long as the TV stays plugged in.
Scott out
Jan 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
T.V. problems
broken screen, how much to fix panasonic th-42pd6ou
Oct 16, 2007 | Televison & Video
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
