Question about Dell Dimension 2400 PC Desktop
Need help please
When i open the my dell 2400 pc it says primary and secondary memory not found even i can't see my hard disc in cmos setup. what am i suppose to do
  • 21 Answers
Hello i am bhaigi your computers hard disk belt is may be damage change it and put the jumpher in frist hard disk master and second on slave
Posted on Mar 12, 2008
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
My Dell Opt, Plex GX 260 reads "Primary hard disk 1 not found, and secondary hard disk 2 not found" ? please help?
You can reseat both cables for both hard drives, however its sounds like the mother board is bad.
Oct 20, 2010 | Dell OptiPlex GX260 PC Desktop
My primary drive 1 an 2 not found how do i fix this
well primary drive is the hard drive from which the OS boots so if it is not detected PC cannot boot so check exactly which drive is not found and you can also check the power cable to the drive which is not found and make sure it gets the power .
good luck.
Jan 06, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
It doesn't boot from hard disk
can you still go to CMOS SETUP?
how many beep and beep long of your pc while booting?
if you can still go to cmos setup try delete all partition using your windows setup then install a fresh copy of windows. if there are no partition found means theres a problem with your hardisk try put your hard disk to secondary if in primary or use different data cable might be the problem if the data cable is not the problem see the power supply of your hard disk is fine try swap the power suppply of your hard disk and cd-rom drive or extra power supply if power supply is not problem .
Buy a Brand New Harddisk might fix it your hard disk might have plenty of bad sector thats why doesn't boot anymore.
Hope i help you out ^)^
Jul 01, 2009 | ASUS P4SGX-MX Motherboard
Hard Disk failure
Try to run CHKDSK from command prompt, and if that doesnt work, its probably corrupt / hard to recover
Apr 21, 2009 | Dell Dimension 2400 PC Desktop
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
Problem with Dell Dimension2400PC
Hit F2 to run setup.
At the HDD set up portion leave Primary drive as it is.
Set the Secondry drive to none or automatic.
Nov 05, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
37 people viewed this question
Alun Cox
