Question about Canon PIXMA iP1600 Printer
Canon Printer iP1600
After changing my cartridge (which I have done tons of times in the same way), my printer doesn't print anything. The paper goes through and it makes a printing sound, but nothing comes onto the paper. Pls. help....
Thanks, Inge de Water
Hi FixYa team,
Thank you for your mail. No, I didn't find a solution to my problem yet. I also contacted the Canon Support and got some suggestions and questions like: What inks are being used in the printer? Have to state the type of ink that is being used and the order that the tanks are installed in the print head. I also have to provide the exact part number (such as BCI-6C, PG-40, etc.) imprinted on the ink cartridge.
I have to complete two deep cleanings, and perform another
Nozzle Test. If colors are still missing, I have to turn off the printer. After
24 hours, turn the printer on and perform one more Deep Print Head
Cleaning. Once the cleaning is complete, print another Nozzle Test.
After I have completed the Nozzle Test, I have to let them know the
results.
I haven't done all these things yet, so when I have I then will know whether or not the printer works. If not, the only other solution is to buy another printer, which will probably be an Epson, 'cause I'm not too happy with this Canon one.
Thanks again for your interest and kind regards,
Inge de Water
Posted on Mar 13, 2008
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    I refilled the ink cartridges on my canon mp250 printer. Now the ink lights will not quit flashing and I am unable to print anything. I tried resetting according to instructions provided by canon and it...
    How much time you have done refilling a same cartridge? You shouldn't refill a same cartridge more than three times. Make sure that the cartridges are OK. May be the head of the cartridges are not in good condition. You may need to replace cartridge. Check that you have installed the cartridges properly or reinstall it. Align the cartridges. If it doesn't solve your problem then you have to replace the cartridges. Using original cartridge always is recommended.
    Jun 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Describe your Canon PIXMA iP1600 Printer Problem
    Hi You can Try 2 things.
    ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
    Next try.
    It may be a piece of paper or a scotch tape or a staple wire.
    Solution 1:
    Clean the timing strip.
    Solution 2:
    The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
    Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 16, 2010 | Canon PIXMA iP1600 Printer
    I put blue ink in a black cartridge and from then
    Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
    Compliments and wish you best of luck.
    Jan 02, 2010 | Canon PIXMA iP1600 Printer
    I bought a refilled black ink cartridge for my
    Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
    Nov 24, 2009 | Canon PIXMA iP1600 Printer
    Canon ip1600 ink cartridges are not recognized?
    First make sure you are placing the right
    color cartridge into the right slot.
    Most Printers are touchy about the
    installation of ink cartridges. If the
    instructions say to press the cartridge
    into the slot until you hear a loud click,
    that's what they mean. If at first you
    don't succeed, remove the cartridge and
    reinsert it into the slot again and press
    on it hard till it clicks.
    Then your printer should work properly.
    Hope this is of some help. Bud
    Nov 01, 2009 | Canon PIXMA iP1600 Printer
    Help!Have Canon printer.Changed cartridge, but can't print!
    Hi there
    You can try this it some times works.
    Super Canon User's method of resetting IP1600
    1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
    2.Open the cover right away
    3.Release Both cartridges out and then put cartridges them back again
    4.Close The Cover
    5.Turn Off Then Turn On again.
    You can download the Resetter tools program from my website.
    Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
    1. Download software for Canon iP1200, iP1600, 2200 Printers.
    2. Unzip downloaded file by etc
    3. Run GeneralTool.exe
    4. Select the connected USB port number from USB PORT
    5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
    6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
    If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
    Free WinZip http://www.winzip.com/downwz.htm
    Please call back to vote
    All the best: Pineworks
    Oct 16, 2009 | Canon PIXMA iP1600 Printer
    I loaded the black ink like I have done so many times before, but a window is coming up saying it does not recognize my color catridge and will not print. I dont even have a color cartridge in the printer.
    Some printers will not print while missing either of the cartridges, was the printer working without the colour cartridge before?
    Try inserting a colour cartridge and see if that helps.
    Dec 09, 2008 | Canon PIXMA iP1600 Printer
    Canon Pixma 1P1600
    printer driver canon PIXMA iP1600
    Oct 08, 2007 | Canon PIXMA iP1600 Printer
    Canon ip1600 wont work
    make sure an select the ip1600 from your print chooser when the print menu comes up. If you have used another printer with your mini, it my be "defaulted" to the old one.
    Sep 02, 2007 | Canon PIXMA iP1600 Printer
    Canon PIXMA iP1600 Printer Logo
    44 people viewed this question
    old marine
    old marine
