My dvd writer din not write a dvd
My dvd rom is working properly but when i write a dvd it write sucessfully at 16x speed.
than it did not read by any dvd writer and combo
    Sergeant:
  • 349 Answers
This is a common problem, all you can do is when you burn the dvd make sure you set the burning software to maximum compatibility mode ,however you may still have problems with some readers.
good luck
Terry
Posted on Mar 12, 2008
SOURCE:
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
My dvd writer was working perfectly but when i format my wondow now it is playing only cds & when i insert a dvd it is not giving any response & my driver is also showing as cd-rom
When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to www.driversguide.com and find it there.
Dec 17, 2009 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
LG GH22LS40 will not work
You will need to check few things to get it working.
1) See that you have attached your DVD cable on the proper port of your motherboard.
2) See that the required jumper is fixed in proper place of your DVD writer.
3) Power cable of your DVD writer.
All the Best
Sep 11, 2009 | LG Electronics 16x DVD and 48x CD-ROM...
Cd is not reading by dvd writer but dvd is running smooth
1.when you write on dvd writer always select low speed to write such as 8x or 16x
2. most of the dvd writer do max speed while wrting the Cd or Dvd
3. due to this reason your cd is not reading
4. you can try a new disk write in slow speed,then check with your cd.
Jun 22, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
My dvd writer became dvd rom only, now I am unable to wirte the cd and dvd by using my dvd wirter which I bough 3 months back
in these case your dvd writer became dvd rom due to optical lens problem. some other case dvd can read only cd or became cd rom also due to optical lens problem. change the optical lens or adjust trimmer for laser.
Jun 10, 2009 | Philips LITE-ON 20x DVD RW Drive -...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Dvd rom
Geoffrey Thomas the writer. I have writen an artical why CD and CD and DVD's don't work in DDV players, recorders, laptops and PC's rather than what could be wrong. Some of the pointers my provide an insight itno what could be wrong may be of some help. If interested contact me at the emial adress given.
Apr 27, 2008 | LG Electronics 16x DVD and 48x CD-ROM...
Pioneer DVR-109 DVD±RW...
This ahs to with speed of recording of the CD/DVD try reading CD/DVD burnt at a lower speed like 16x.
Most DVD writers has low maximum reading speed as compared to CD-ROMs.
You can try burning a CD on it and then reading it, if reads then it shows that other cd were burnt at faster speed than it can read.
If it read lower speed CDs then you can just add an additional DVD/CD-ROM just to read faster speed disks.
Mar 24, 2008 | Pioneer DVR-109 (44121479) DVD±RW...
Why my pc does not work with 16x DVD
the dvd reading capability of your drive could be less than that of the dvd speed,,,,
Dec 30, 2007 | Samsung Sony 16X IDE DVD-ROM Drive DVD...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Open Questions:
    Computers & Internet Logo
    65 people viewed this question
    Ekse
    Alun Cox
