I loss my remote control for Hatachi multi-system 32" model# C29-F800SNT and I am trying to find a place to a new remote control. Thanks
  • emekanwuha Mar 12, 2008
    My is 6270 STILLWATER DRIVE, RIVERDALE, GA 30274 USA. Thanks
  • 19,396 Answers
If you tell me your location I can find contact to get a replacement remote in your area.
Thanks
Posted on Mar 12, 2008
  • Ginko
    Ginko Mar 12, 2008
    Here you can buy remote for 65$ it is an US company. They ship in many locations.
    Here is same item in UK.
    I will need more details about your location to find specific sellers in your area.
  • Ginko
    Ginko Mar 12, 2008
    If you are in USA try using first link, price is very good, it costs double the amount here in England.
Tell me the remote control model no of hitachi C29-F100
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 13, 2014 | Hitachi C29-F100 29" TV
LOST COLOUR: C29 F500DR The colour seems to have disappeared on my Wow by srs C29 F500 DR. I have a digital set top box attached. I cannot seem to restore colour. Any adjustment of the picture via remote...
I suspect that you have connected via componet I would check the red green and blue cables
you may have lost a one of the colors but check the cables first
is it b/w on it's menus?
if it is you have a color element out
Sep 22, 2008 | Hitachi Televison & Video
I have a hitachi c21- f800snt 21" Ihave no
To release the child lock, you must have its remote control.
Oct 14, 2013 | Televison & Video
2001 maxima alarm not working but panic works
ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Jan 03, 2018 | 2001 Nissan Maxima
I need the part number or code for a FLYBACK for a TV Hitachi Model C29-F800SNT
I'm sorry for this bad news but, the part that you seek is not available and , has been discontinued.
May 26, 2009 | Hitachi Televison & Video
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
Remote control for hitachi 42pd9500
wear which is just universal remot of easier package earn. Thanks www.modifmax.com
Feb 08, 2008 | Hitachi CLU-5713TSI Remote Control
Un lock child Lock.
Here is the link for the manual; http://www.hitachi-hk.com.hk/FileManager/EN/UserManual/CTV-C29-RF80SNT(Eng).pdf page 15 towards the bottom - unfortunately you can only remove the child lock with the remote. If you look on the remote (possibly inside the battery compartment) it should have a model number - sorry i had no luck yet finding it out online - let us know that, and we can try and source a new remote for you. Try searching for this remote; DYNATRON MR160 MIRACLE REMOTE CONTROL It is designed to control all hitachi tvs from 1988, including all the hitachi brand specific functions and seems readily available, no link because you will find lots, maybe somewhere close to you. Sorry if bad news; hope it helps :)
Mar 25, 2007 | Hitachi C29-F800S 29" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
