Question about Apple iPod nano
"IPod Problem "
"my ipod says press menu key to format and other keys to not format " what to do after formatting also it says this. Is there any programme to fix this or what the thing going on
  • Apple Master
  • 13,433 Answers
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Also try the ipod updater from the apple site.
If that doesnt help contact the apple support.
Posted on Mar 12, 2008
Ipod frezzes up & won't shut off any clues on how to fix??
To reset the ipod, move the hold switch on and then off again, then press and hold the select and menu buttons. It should reset in 6-10 seconds. As far as fixing it to keep it from resetting, you need to format the ipod which will delete all the music on it. To format you plug it into itunes and under the properties for the ipod there should be an option to format the ipod.
Jul 20, 2009 | Apple iPod U2 Special Edition MP3 Player
I synced an mp4 video to my ipod nano (my first video) but it doesn't play. The video shows up on the menu, but when I press play, it sometimes only shows a blank screen with the seconds passing by at the...
its most likely that the video you placed on your ipod has different format/type. you need to convert first your video to the appropriate format.
check for the file extension/format of the videos you can view/watch from your ipod! (look for the sample video with its file extension/format)
Jun 14, 2009 | Apple iPod nano
IPOD is hanging but can't be reset.
i would try reformatting your ipod to factory specs (can be easily done with itunes following the information provided at mac.com)
to reset the ipod, turn it off, then on -- then hold down the 'menu' key while pressing the center 'click' key until you get the apple logo. this just may solve the problem.
Apr 25, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I had my ipod connected to computer hearing music then i disconected it and know it wount turn on.help please
Plug it into a wall charger if you have one, or back onto the computer to see if it will charge, as it might be a low battery issue.
If not, press and hold Menu and select/center, until the ipod reboots/resets, and you see the apple menu. Then your ipod should be working.
If it still does not, press menu+select again to reset, but right as it shows the apple logo/when you hear the hard disk moving (if you have a video/classic/one with a hard disk) move your finger from menu to play, while keeping your finger on center. This will engage Disk mode, where you can plug it into your computer and format the disk.
This will erase all songs/data. once you have formatted (to FAT32) through My Computer (by right clicking your ipod, and clicking format) Open iTunes and 'restore' your ipod, which will reinstall the firmware/software. For formatting, you can do 'quick format' if you want, it doesn't matter.
Hope this helps!
Feb 27, 2009 | Apple iPod MA446LL/A MP3 Player
APPLE I POD ERROR 1439
Hey check out this link it worked me.. http://inc0gnit0s.wordpress.com/2009/07/19/error-1439-while-trying-to-restore-or-sync-ipod-with-itunes/
Dec 15, 2008 | Apple iPod classic MP3 Player
Help me China Ipod Shows
Might be a problem with the storage device, does it work even if you dont format? if it doesnt work when you press dont format. then I recommend you try the format.
let me know how it goes.
May 01, 2008 | Apple iPod MP3 Player
Ipod is not working
connect the ipod to the computer or power outlet, turn the hold switch on then off again, then press and hold both the MENU and the center button. The ipod will reset and the data will not be lost. if that doesnt work try this: try going to the device manager by right clicking on my computer then under the hardware tab. if you see an icon in the drop down list with a yellow exclimation mark beside it then thats why. right click on the icon click either uninstall or reinstall. if that doesnt work it might be the usb drives are not 2.0 combatible.. but that is highly unlikely. another solution might be to look in the windows driver archives and try to locate an ipod driver. if not the simplest solution might just be to use a diffrent usb port, and if you are using a usb hub try going straight to the computer instead of through the hub.
good luck
please mark the post with a fixya
Feb 21, 2008 | Apple iPod nano 3rd Generation
4GB DIGITAL MP4 PLAYER
Please note that you may not have a genuine Apple iPod. iPods don't have hourglasses, and don't say MP3 or MP4 Player on them. The cable should also go into the player via a wide flat plug. To check to see if you have a genuine ipod, put your serial number into https://selfsolve.apple.com/GetWarranty.do .
That said, You may want to try formatting the player. Your Firmware could be corrupted. If it works with itunes, click restore. Otherwise, right click the drive in my computer and select Format.
Jan 11, 2008 | Apple iPod nano
Frozen screen and different format
Hold the Menu and Center Button until the screen goes blank.
you will then see the apple logo and you should be set.
Nov 29, 2007 | Apple iPod nano
Mp4 problems
boogie31 - Go to Windows --> Control Panel --> Printers and Other Hardware (I am assuming you are using Windows XP) --> System --> Hardware Tab --> Device Manager - see if any devices under Universal Serial Bus Controllers have a yellow exclamation mark by them. If so, then double click the device and select the "Drivers" tab in the next window. Then click on Update Drivers.
nikes - Use your transfer program (Windows Media Player, Media Monkey, etc) to select the Properties or Advanced Tag Editor option - then you will be able to change the language. Give me your program name, and I can get more specific.
-Tha Mp3 Doctor
Oct 01, 2007 | Apple iPod nano
Apple iPod nano Logo
74 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
