Stactic looking screen
The screen looks like it has static intefirence this the best way i can decribe it i dont know how this has happened as the computer was iven to me this way....the strange thing is yesterday when i pressing the mouse buttons the screen went normal for about half an hour then it just went back by it self.. does any one know what is wrong with it and how to fix it..... thanx
  • jloew Jul 27, 2008
    My Dell Inspiron 1000 PC would sometimes give me a static screen and now it gives me that all the time and I cannot use it.
  • 36 Answers
There are two causes for this problem..
1. Your LCD screen is worn out or has internal lose connections..
2. There is a heavy layer of dust inside your laptop which is to be removed using a soft vacuum cleaner..
there are other rare reasons like the keypad is loose and you might have to refix it by removing and blowing air onto it and fix it back..
Posted on Mar 12, 2008
Screen flickering with lines and static.
I would install Windows and see what happens.
Mar 06, 2014 | Acer Aspire 4720 Notebook
When I turn on my WS65611 rear projector TV the picture comes on perfect but after a minute it starts going static then the picture will come back on then it goes stactic. This continues for as long as the...
A few things you could and should try, try something on a different input if you are using the coax connection just to know if problem exists that way, could be a bad tuner but that can be got around, also if on all inputs the set does have a hard reset that requires the Mitsubishi remote and a four digit code to enter the hidden option menu.
check the other inputs first please and let me know.
Aug 27, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Replaced power socket on motherboard. Now it will not boot with the recovery disk. Screen is blank. Did static destroy the board? How do I know. Computer worked fine before repair.
Who done the repair? Thats not the easiest job to do considering what you have to break down to get to that cornor of the board. If a shop done it you should be able to take it back and you already know the answer to your question about static. If the job was done sloppy and the sodder got to a part of the power grid on the board there would be your issue. If the sodder got where it wasnt supposed to be your looking at a dead shorted board. I charge about a hundred to do that job although the part is only $2-$3 dollars the time it takes to do it right is about 2 to 3 hours. If you done the job yourself this will be an expensive lesson of why you buy a $5 static band when breaking down a laptop or any static sensitive device. Honestly although the damage may be done and your feeling frisky BUY the wristband tear it down again look at your sodder job you may get lucky......Best of luck hope you get it going
Dec 29, 2009 | Compaq Presario R3000 Notebook
My aspire one has a black screen when turned on green light turns on when power botton is pushed but screen never comes up
Hmm. Try F8 or ESC. I Have the same computer. Once when It did that I had like a bajillion viruses. Maybe this will help. Best of luck!
Nov 29, 2009 | Acer Aspire One PC Notebook
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
LG screen out
Bad logic board.Always replace this along with y and z sustain boards.On some LG/Zenith sets they come as a replacement part kit.
Jan 10, 2009 | LG 50PX1D 50 in. Plasma Television
Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Dec 21, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Lots of static when playing over the stereo speakers, and the screen seems loose
sorry but what u have is called a fm modulator some are adjustable some not go to your local car audio shop to find out or take your headunit out and look behind it if so tune the fm mod to a different station one thats not being used there are three preset station on the fm mod but remember just because theres no station on that radio channel were u live dont mean there wont be one when u go into town thats the bad thing about fm mods best thing to do is get a indash cd dvd radio and as far as the lose screen just hand tighten the screws flip down the screen look up there should be 4 or 6 screws there just tighten them up a little this is normal
Dec 18, 2006 | Farenheit MDM-830CM Car DVD Player
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
