Toshiba Satellite A205-S5804  PC Notebook Logo
Posted on Mar 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to connect my toshiba satellite a205-s5804 laptop to my sony bravia lcd 1080 t.v. I have connected VGA from laptop to t.v.VGA pc in on t.v..Also headphone out to sound in on t.v.. T.V. not excepting signal from pc,so pc input lite on tv not on.(no signal in) I also toggled fn+f5 on pc to alow 2 monitors,also lowered resolution down under 1080, since t.v. is 1080. T.V.not detecting a signal from pc. So what can i try next? What am i missing? THANKS for all your help.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 164 Answers
  • Posted on Mar 27, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
164
Questions
Helped
28600
Points
422
Please double check that your VGA cable is working properly and you have installed the most updated version of video drivers.
Is the TV not even playing the sound? Are you on the right channel? Only try checking the sound on a AV channel by using a headphone jack to AV jack cable.
If you have a S-Video port try connecting with it you can get that cable for a buck in a dollar store.
Hope this helps.
My monitor is black but i can still see the desktop somewhat. what could be wrong with it?
Your lcd's inverter has gone bad. Google: "Toshiba Satellite A205-S5804 Inverter". They're about 20 bucks. Then to replace Unscrew or pry apart your screen bezel and it will probably be under or above your lcd. Then just unplug and replace.
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
http://en.wikipedia.org/wiki/VGA_connector
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
I need ethernet drivers for my Toshiba Satellite A205-S5804 laptop
I think you can try this link to download the driver for your ethernet. Hope it helps.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1909174&rpn=PSAF3U&modelFilter=A205-S5804&selCategory=2756709&selFamily=1073768663
AnEspera
My girlfriend has a PSAF3U-0NR00V Toshiba laptop and the monitor gave out. Any way to get a replacement without buying a whole computer?
Yes, you can change just the LCD screen. In this case, for Toshiba PSAF3U-0NR00V Satellite A205-S5804 you need part number V000061680 which ranges around $150.
Here is a parts seller for reference: http://www.sparepartswarehouse.com/part.aspx?partnumber=V000061680&mfg=OEM&sdevicetype=Laptop
How to connect my toshiba satellite a205 s5804 laptop to my hd tv.vga input on tv.
you should be able to get a VGA Lead that you can plug into your laptop and the other end of the VGA cable into the VGA input on the TV
ON the TV :- Select the PC input ON the LAPTOP :- use the FN + one of the F keys, these vary by manufacture but F4 or F5 - look for a symbol of a Screen - each time you press this F+F? key, this will then toggle the out put to <Laptop><Laptop and TV out ><TV out >
Laptop needs cd recovery
I'm trying to restore my toshiba A205-s5804 but i don't have the disc. Can i restore it with out the cd?
2answers
Wireless
what operating system are you using?
Hard disk help
Hi
I have Satellite A205-S5804
Im try to download wendows xp to my lap top
Iwas do it successful
But I cant find any driver for my lap top
Like vga –Ethernet- sound-display-wireless
Plz can u help me
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
