Question about Technics Audio Players & Recorders
Technics SC-CH770. Tape deck just keeps clicking when trying to listen to a tape, it tries to go forward then it tries to go back but then just stops. When I take the tape out it has moved a little and there is a small amount of spare tape coiled inside the cassette which is easily wound up. The fast forward or fast reverse do not operate either, it just results in the same thing happening as above.
Cassette section malfuntions sometimes play somtimes doesent eject
Posted on Aug 17, 2009
Finding a Microcontroller for a Technics Tape Deck
I am sure there is one available or suitable sub . I wonder if technics would provide more information if you contacted them or a local electronics store.
A microcontroller may or may not be programmed for a specific purpose so, that also may be an issue if not purchesd froma source used for that device.
There is also a forum called tapeheads:
Technics RS-B49R - Tapeheads Tape, Audio and Music Forums
www.tapeheads.net >
http://www.tapeheads.net/showthread.php?t=49248
I found some links here and even a few sold for parts around 15 bucks:
Google
https://www.icom.co.jp/world/support/download/manual/disp_down.php?SWT=&ID=20010101177&GNR=Amateur&TYPE=Mobile&PDNM=IC-901A/IC-901E&INQWORDSWT=No&INQWORD=
Mar 26, 2017 | Panasonic Technics cassette deck rs-br465
Technics tape deck rs-eh600 wont play it just clicks
Another dual deck it seems- the unit will need service by a Technician, there is no magic that will make it work. It may be as little as a large belt. I would have to see the unit to tell you the exact cause.
Aug 13, 2012 | Technics Audio Players & Recorders
Technics RS-CH770
It could be a belt that is not working right. But it could also be a fault on the drive itself. Check the plastic parts for damage.
Oct 01, 2017 | Technics Audio Players & Recorders
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
A LOOP OF TAPE KEEPS GETTING PULLED OUT OF CASETTE WHEN YOU TRY TO PLAY IT.PLUS,IT SWITCHES BACKWARDS AND FORWARDS BETWEEN DECKS WHEN YOU PRESS THE PLAY BUTTON
FIRST TRY FAST FORWARD AND THEN REWIND. Allow it to ff and rew right to the end of the tape. on the tape. do this a couple of times. this may cure it as it sounds like the tapes are getting an imbalanced tension. If you still haver the problem, dip a cotton bud in alcohol and clean (carefully) the pinch wheel (the rubber bit that drives the tape through) and the capstan (the metal bit the rubber wheel presses against).
Oct 07, 2009 | Technics Audio Players & Recorders
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
SANSUI SC-2100 RECORDING PROBLEM
First try cleaning the heads with some electronics grade alcohol and a static free cleaning swab...although it sounds like the head may need alignment...if those two things do not work out for you, the capstan motor might be the culprit.
Jun 22, 2008 | Technics Audio Players & Recorders
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
431 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
