Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Audio out of sync
My 4 month old lcd hdtv has an audio problem. The audio does not syncronize with the video and there is a delay of about a half second gap between the person's lip movement and the voice. I mess around with the audio chioces on the menu and it temporarily stopped a few times but comes back. Any suggestions?
2 Suggested Answers
SOURCE:
snakehead
  • 1074 Answers
SOURCE: sounds don't align with lip movement
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Posted on Jun 23, 2007
VIZIO E470VA LCD HDTV audio and video are not in sync
Go to your On-screen Menu, go to settings, select audio, then select LIP SYNC. You can then adjust the amount of shift to synchronize the pix and the audio.
Sep 07, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have my Onkyo tx ds656 hooked up to my HDTV via the cable box. Everything works fine, except that there is a noticible delay in the syncronozation of the sound and the video. Is there any way to correct...
It's the nature of the beast. The TV has to process the digital video bitstream more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. I didn
Jan 24, 2011 | Onkyo TX-DS656 Receiver
I have a Yamaha RX V800 AV Receiver is their an lip sync adjustment for internally with this amp.
This monster has a lot of built-in opportunities to tune or mis-tune the sound but nothing to deal with the effect you're addressing.
A discussion of lip sync:
http://en.wikipedia.org/wiki/Audio_to_video_synchronization
  • There is extensive use of audio and video signal processing circuitry with significant delays in television systems. Particular video signal processing circuitry which is widely used and contributes significant video delays include frame synchronizers, digital video effects processors, video noise reduction, format converters and MPEG pre-preprocessing.
  • The video monitor processing circuit may delay the video stream. Pixelated displays require video format conversion and deinterlace processing which can add one or more frames of video delay.
  • A video monitor with built-in speakers or line-out may not delay sound and video paths by the same amount of milliseconds. Some video monitors contain internal user-adjustable audio delays to aid in correction of errors.
  • Dec 31, 2010 | Yamaha RX-V800 Receiver
    I converted an MP4 file to AVI and when i play the movie on quicktime the audio is out of sync and the movie plays like its on fast forward. i am trying to upload it on youtube and when i put it on youtube...
    Hello.
    Give this a try:
    Download the latest version of AVI audio sync tool: YAAI_2.0.3.488.zip
    from http://findfiles.com/list.php?string=YAAI_2.0.3.488.zip&db=Mirrors&match=All&search=
    First of all, make a backup copy of your avi file (this is very important!).
    Step 1. Unzip YAAI_2.0.3.488.zip file. Launch YAAI.exe , "Open AVI" dialog will appear.
    Step 2. Find and open your AVI file.
    Step 3. Click on "Sync Audio" tab. Small video player will pop up.
    Step 4. Now, adjust audio delay or frame rate (FPS) using sliders or appropriate buttons.
    Click Apply. Video player will start playing your file with changed settings automatically. You can adjust and apply these parameters several times to pick up necessary values for audio delay or FPS. So, try to experiment and to set appropriate audio delay or to change FPS (frames per second) settings for your avi file.
    Step 5. Finally, close YAAI tool. When it asks the question: "Do you want to keep the changes?", click Yes.
    Hope this helps.
    Feb 02, 2010 | Computers & Internet
    Audio & video sync problems
    I would advise you to call LG's customer service at 800-243-0000 to set up service. There is a service bulletin about this issue specifically for your model. Your set requires a simple software update to fix the audio delay with HDMI issue. You can ask LG's customer service to refer to bulletin #0IVL20080379. Hope this helps.
    Jan 07, 2009 | LG 37LG30 37 in. LCD HDTV
    Am i getting hdtv with just cable feed?
    Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
    Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
    Gh world tour mic has terrible lag
    Yes, unfortunately, USB ports just aren't fast enough for live vocals. Some stereo setups have longer lag times than others, as well. A couple of ms is very noticeable. Have you tried adjusting the settings on the game? Go to "Options" on the Home Screen and select "Calibrate Lag." Here you can delay either your Audio or your Video in 1 ms increments to try to adjust for lag times. You may find a happy medium after adjusting these settings.
    Dec 28, 2008 | Activision Guitar Hero World Tour Guitar...
    Microphone delay for Rock Band
    should be video delay settings in the game, this is a common issue with hdtv's, the issue is not that your audio is delayed but your video is delayed making illusion that your audio is off.
    Aug 20, 2008 | Sony PlayStation 2 (PS2) Console
    ILO-26HD Audio & Video
    I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
    Feb 06, 2008 | iLO 2600 Television
    Sound/Video delay
    Lip-sync error is a widespread problem caused when video is delayed and audio arrives too soon. Widespread enough that three different manufacturers make dedicated products to address it, in fact (see review link below for those three). It is present to some extent in essentially all broadcasts and DVD?s. If you have a recently acquired DLP, LCD or plasma display it may have added enough additional video delay to make it noticeable but lip-sync error comes from MANY sources starting at image capture and continuing through post production and broadcast or DVD encoding and it is cumulative. There is usually enough lip-sync error in broadcasts and DVD's to cause a negative impact on viewer perception (Research done at Stanford showed this.) Many people don't consciously notice it until it gets very large because it's such an unnatural phenomenon ( audio can't come before the action causing the sound in the real world) we apparently subconsciously avoid looking at the faces and seeing the lips move "after" the sound from them is heard. A study at Stanford proved this causes negative viewer perception even for those who don't notice it so this is something we all need to notice as you already have. For those reading this who haven't noticed it, take a close look at the LIPS - force yourself to overcome your natural avoidance mechanism that keeps you from looking at the lips - and you will see lip-sync error you never noticed before. I think you will be amazed that you could possibly not have noticed it before. You will be seeing what JC is seeing. I even see it now on CRT TV's and am amazed I never noticed it so it's very obvious some avoidance mechanism is at work. And back to JC?s solution: I'd recommend one of these digital audio delay units. That way you can correct for ALL cumulative lip-sync error no matter what its source might be. Any one of these units reviewed will correct it ALL. With any one of these units you can adjust for perfect lip-sync at the start of each DVD or broadcast and not disturb the image you are watching during that fine adjustment. I have had a Felston DD340 since 2004 (three generations earlier than the DD740 covered in the review) but it still has the most important feature of all these units from these three different manufacturers which is their "plus and minus" buttons on their remotes that allow you to tweak the delay while watching your material without upsetting the video your are watching. My av receiver has a built in delay of 80 ms which isn't even enough audio delay to offset the video delay my plasma display adds but even if it were it isn't practical to adjust it for the changes in lip-sync error from program to program and DVD to DVD since it overlays the screen with menus when making the delay adjustment. With my DD340 (and any of the units reviewed) all you have to do is press the plus or minus button until you get perfect sync. Here is the review I mentioned: [URL="http://www.audaud.com/article.php?ArticleID=3011"]
    Aug 30, 2007 | Audio Players & Recorders
    Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
    49 people viewed this question
    Top Westinghouse Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
