My usb port is not working, and my laptop was not turning on untill i disconnected my battury , but mu usb ports are still not working. modle of the laptop is ls50a and the make is LG thank you for your help in trying to help me , may god rewared you . maz
  • 133 Answers
U need to do a thorough harddisk check and virus scan
Posted on Mar 12, 2008
I need proline w258cuq usb drivers
Here is a site with a comprehensive list of drivers for your computer. proline w258cuq lan
Mar 01, 2015 | Computers & Internet
I have a Logitech cooling pad for my Dell 17" Studio laptop with 4 GB RAM and Vista Home Premium. It mysteriously stopped working. When I plug the cooling pad in other laptops, it works fine. I have...
Seems that your laptop's USB ports are not providing enough power to the cooling pad. This could be due to you connecting too many USB peripherals to your laptop. Test if you can get the cooling pad to work by disconnecting all other USB devices.
As a permanent fix, you can buy an active USB hub (one powered by external power source) & connect your cooling pad to it.
Dec 18, 2010 | Computers & Internet
My mouse doesnt get detected on my system. please help
Instructions
  1. 1
    Turn off your computer.
  2. 2
    Unplug the power supply, remove your laptop batter, and wait at least 30 minutes before returning the battery and power chord to the laptop. As explained by Trouble Fixers, a cache of data from your USB device is stored on the motherboard. This cache is not completely erased until the motherboard fully discharges following power-down. Once the cache is cleared, most USB errors will be fixed.
  3. 3
    Turn on your laptop computer.
  4. 4
    Try to use the malfunctioning USB port. In most cases, simply turning off and unplugging the laptop will help remedy the problem. If a problem persists, continue with Step 5.
  5. 5
    Click on the "Start Menu."
  6. 6
    Click to open the "Control Panel."
  7. 7
    Click on "System and Maintenance."
  8. 8
    Click on the "Device Manager." A new window will open that lists all hardware and external devices currently installed on your laptop computer.
  9. 9
    Scroll the list until you notice the heading "USB Root Hub." Click on this option.
  10. 10
    Select the USB port that reads "Unknown Device." All other, functioning USB ports should say "unused port" or list a specific external USB device.
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed
  12. to forget to leave your comment and testimony
Oct 05, 2010 | Computers & Internet
My usb connector malfunctioning
Instructions
  1. 1
  2. 2
  3. 3
  4. 4
  5. 5
  6. 6
  7. 7
  8. 8
  9. 9
  10. 10
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed.
dont forget to leave a comment and state how helpful this post is to you
Oct 05, 2010 | Nokia N70 Cellular Phone
Dead USB Ports...
First go into Device manager and see if there is a Yellow! or a Red (x) next to any of the USB ports. If so right click and there will be a tab with solutions. If that doesn't get you anywhere go into BIOS and search for all of the USB ports. You should be able to add or turn onto Automatic to get them going. USB is simply a port, so some kind of the way the ports either got shut off or they are blocked.
Dec 24, 2008 | HP Pavilion dv6105us Notebook
Wireless Gigaware 26-990 unable to connect
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 24, 2008 | Computers & Internet
USB Port has failed; 4E00:032B
Electrical surge on hub port. Either a device attached to the port, or the port itself, has drawn more current than allowed, and the hub turned off the port. The port will not function correctly until you reset it. If the device is the cause, it must be detached before resetting the port. To reset the port, disconnect the device, and then click Reset in the dialog box. If the port is the cause, close the dialog box, and do the following to re-enable the port:
Disconnect the hub.
Re-attach the hub.
If it is the root hub, unplug all attached USB devices from the computer, and (if they have power supplies) unplug them from the electric supply. After a few moments, reconnect the devices. The computer can be restarted at any time.-->
Dec 22, 2008 | Dell Inspiron B130 Notebook
Open Questions:
TechUSA/CA&1.877.778.89.69&Avira Antivirus Support Phone Number? Call 1-877-778-89-69 is followed by great amount of people because this number is used for solving the issue of virus's problem . It works with the assistance of Avira Antivirus support phone number and therefore the number is 1-877-778-89-69.Our expert will give advice to you how can you protect better and faster your pc's or Laptop and other devices.Our Team is very experts and experienced. Avira antivirus offer technical support in a very price effective manner by means that of tollfree service at 1-877-778-89-69.Sometimes customer face the problem of pc or laptop hanging.you must tried to use that number to solve the problem of virus's or hanging problem.Our expert always available for solve the problem you just dial 1-877-778-89-69 and your problem will solved in sort time.So use that number for any Antivirus problem.It provide the facility of shorter wait time and faster help.If your computer is infected please call 1-877-778-89-69.USA TollFree No:-1-877-778-89-69.Our customer Centre is all Always Opened in24*7.We are Avira Antivirus Support USA. For Any Query Call US :-1-877-778-89-69 . Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number,Avira Security Tech Support Number,Free Avira Avtivirus Customer Support Number,Avira Customer Service Tollfree Number.
May 29, 2017 | Avira Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
