Question about Recoton Advent Advent Q2035A 20" TV
Istalling mouseb has turned off touch pad ?
Since installing a mouse and driver to my lap top the touch pad wont work .i cant see anything onm vista control panel to turn the touch pad back on. any ideas welcome
  • 298 Answers
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Posted on Mar 13, 2008
  • F1forHelp Mar 31, 2008
    I might add that some laptops can use multiple mice input.
SOURCE:
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Apr 10, 2013 | Acer Aspire Computers & Internet
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Apr 29, 2011 | Computers & Internet
Mouse quit working on my Lap Top it is a Aspire
First of all check whether the touch pad is lock (Fn+F7(?)). If you use an external mouse/ usb mouse, check usb cable connection, as long as you didn't drop it on the floor it should be ok. If the built in touch pad doesn't work, could be caused by ribbon cable connectivity that has dirt or moist. To fix it need to open the upper case
Apr 08, 2010 | Computers & Internet
My mouse on my compaq lap top is terrible The
hello,
Please reinstall the touch pad drivers once and if then also it is not working the needs to be replaced.
Thanks
Dec 10, 2009 | Compaq Presario Notebook
I cant get my mouse pad to work after turning it off in control panel. Im on windows vista and on a lap top. Curser wont work so cant go back in to turn it on again.
Hold the Alt key and press F4. Press Enter to shut down the computer.
Once it's shut down, press the POWER button on the computer's system box to turn the computer on again and reset it back to normal.
Hope this works.
Jul 20, 2008 | Acer Computers & Internet
I have a new optical USB mouse but the windows vista on my lap top did not recognise it it sea it but need driver to install it i tried every sing on the lap top to find solution but failed regarding i...
Usually Vista does not need driver to install an USB Mouse.
Try this:
Turn off the laptop, then put the mouse connection. Turn on again. See if now it is working. The mouse should be connected in "off"
If still does not work, try put in other USB port of the laptop. Usually a laptop has at least 2 USB port. Remember to connect it always in "off".
Apr 03, 2008 | Computers & Internet
Curser frozen
did u turn off ur touch pad.
did u check by useing an usb mouse
Jan 04, 2008 | Compaq Presario X1000 Notebook
Mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
Nov 30, 2007 | KEIO PS2 Optical Scroll Mouse
Recoton Advent Advent Q2035A 20" TV Logo
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
Ekse
Inno Laur
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
