Steganography i want the java code for embedding images using auxiliary carry method and modified auxiliary carry method
    Problem Solver:
  • 10 Answers
U can find it from websites by google .java: embed
which gives list of websites that are enabled
Posted on Mar 15, 2008
I need to know how to program a RCA universal remote RCU404N
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
What is the purpose of java
high-level programming language developed by Sun Microsystems. Java was originally called OAK, and was designed for handheld devices and set-top boxes. Oak was unsuccessful so in 1995 Sun changed the name to Java and modified the language to take advantage of the burgeoning World Wide Web. Java is an object-oriented language similar to C++, but simplified to eliminate language features that cause common programming errors. Java source code files (files with a .java extension) are compiled into a format called bytecode (files with a .class extension), which can then be executed by a Java interpreter. Compiled Java code can run on most computers because Java interpreters and runtime environments, known as Java Virtual Machines (VMs), exist for most operating systems, including UNIX, the Macintosh OS, and Windows. Bytecode can also be converted directly into machine language instructions by a just-in-time compiler (JIT). Java is a general purpose programming language with a number of features that make the language well suited for use on the World Wide Web. Small Java applications are called Java applets and can be downloaded from a Web server and run on your computer by a Java-compatible Web browser, such as Netscape Navigator or Microsoft Internet Explorer.
Apr 01, 2010 | Computers & Internet
How to get no. of pixels from given image through java
try to embeed the following coding
class ImgMod02 extends Frame{
Image rawImg;
int imgCols;//Number of horizontal pixels
int imgRows;//Number of rows of pixels
Image modImg;//Reference to modified image
//Inset values for the Frame
int inTop;
int inLeft;
Mar 27, 2010 | Computers & Internet
Sir, give me sample java problem! for i can solve.
Look at the method below which finds prime numbers. public class Primes { private static void findPrimes(int nValues, boolean printPrimes) { boolean isPrime = true; for (int i = 2; i <= nValues; i++) { isPrime = true; for (int j = 2; j < i; j++) { if (i % j == 0) { isPrime = false; break; } } if (printPrimes && isPrime) { System.out.println(i); } } } // REMAINING METHODS NOT SHOWN }Implement the method findPrimesFaster in class Primes by copying the code from the findPrimes method and modifying it to have the following features:
  • Uses labeled continue instead of break.
  • Does not require the isPrime variable.
  • Only tries to divide by integers up to the square root of the number being tested.
Sep 25, 2009 | Sun Java Programming Language (cdj-275)
DFT technique in image steganography
Just do a search in your favorite search engine for 'steganography dft' and you should get several thousand results that cover the theory, the math involved, etc. Bing returned 3,380 valid results.
Jul 26, 2009 | Computers & Internet
Can anybody tell me how to convert jpg image to its binary form??
may be this link will help you in making a project
Apr 22, 2009 | Microsoft Windows XP Professional
How to write jdbc connections
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
Jawa void
you should not use arguments in void function in java ... in java pertaining to void the compiler doesn't understand the arguments and treats that as invalid... in c it is ok
Aug 07, 2008 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
UNINSTALL your old version of Java, then Install the updated version, - this works, in that order....
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
