Question about HP LaserJet 1320n Printer
Yellow light What does the flashing yellow light mean next to the triangle symbol. The printer will not work no mmatter what I try
    New Friend:
  • 159 Answers
  1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
  2. There is a paper jam in the printer.
  3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
  4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
    1. Pull the tray out of the printer and remove any paper.
    2. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    3. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    4. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    5. Slide the tray back in the printer.
  5. The tray 2 paper level indicator is stuck. (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
  6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
    1. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    2. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
  7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
    1. Turn the printer off.
    2. Press and hold down the green GO button.
    3. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4. Release the GO button.
      NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    5. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
  8. If the issue persists, please contact Hewlett-Packard's Customer Care phone center for further assistance. at http://www.hp.com/support.
Posted on Mar 12, 2008
SOURCE:
The orange light on my printer is flashing next to the triangle symbol with an exclamation point in it. What does this mean and how do I fix?
Paper could be lodged in printer somewhere. Check front and rear area where paper runs through. Then unplug and try to reset
Sep 02, 2014 | HP LaserJet Office Equipment & Supplies
There is a red light flashing beside the triangle symbol on my cannon lbp5050n. What does this mean?
Hey!
If that happens look in the system tray for a yellow tiangle,click on it and it will tell you the problem!It might just be a empty toner!
Hope it helps!
Jun 28, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
My printer has an orange light showing next to a symbol which looks like a beaker with a triangle of 6 dots in it. What does this symbol mean? Thanks
It the light is solid then the toner is low. If the light is blinking the toner cartridge is missing and has been removed
Jan 15, 2011 | HP LaserJet 1320 Printer
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
Warning symbol on mini cooper
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
Dec 04, 2008 | 2005 Mini Cooper
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
Flashing yellow light
Your printer requires a new image drum
Sep 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
HP LaserJet 1320n Printer Logo
340 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
