Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint wd64 wife turned m/c off during tumble drying cycle now m/c is dead and will not start on a new program. door was opened to release clothes . new wash was selected but when door is closed the m/c will not switch on. all fuses ok and power supply to m/c is ok.????????? Please help. Roy Blake
  • 16 Answers
Check power is at these Points.
  1. Mains filter at top right - Check for live and Neutral Presence.
  2. ON/OFF Switch - Check for Power in and Out when switched on.
  3. Door Lock - Check for Power down 1 wire and when Locked, Power ( Live ) present in 2 wires. The third wire is the Neutral for the door locking circuit. Check this Neutral is OK. - Let me know.
Posted on Mar 16, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Hotpoint WDF740G Dryer not Very Hot
Most likely to be either that the capacitor is defective which starts the motor slowly at first and then picks up speed or the drive belt is worn, usually this happens when the drum has clothes in it otherwise it looks as if it is operating normally
May 22, 2014 | Hotpoint Washing Machines
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Hot point wd64 dryer
U need to check the heater element and/or the stats on the top of the heater box located on the top of the drum for continuity, with a meter.
Disconnect from the supply, and remove wires from components to check for continuity.
Hope this helps u.
Plz rate this solution.
Thanks.
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Ref Hotpoint - aquarius extra - WD64 Washer trips the electric just before the end of the wash cycle. Fault always happen at the same point. If manualy turn nob (on to dry) before end of the wash cycle...
I had this problem. It is not to do with the switch.
The point at which it trips, will be when the spin starts to get fast.
There is a design flaw - and this is particularly easy to see in the dark, as you can see the spark!
The bundle of wires that links to the end of the motor rubs against the motor mount, and one or more wires break through the rubber insulation shorting whenever the drum and motor start bouncing around. Find the break, and use a stack of insulation tape to re-insulate - better still, get a professional to replace the wire.
That worked instantly for me, and have no other problems since.
Tim
Jun 30, 2008 | Hotpoint Washing Machines
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Hotpoint WMA20 First Edition
your bearings have gone and inturn your drum has droped which has cut heater so it has gone 2 earth which is y your electric has triped the whole job should nt cost more than £120 that is what i charge any way 4 a new inner and outer drum supply and fit good luck
Sep 08, 2007 | Hotpoint First Edition WMA20 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
