Question about HP DeskJet F380 All-In-One Printer
My HP deskjet F4810 printer keeps going offline
The printer works normally one day but the next when I go to print nothing happens. Going to My Control Panel/Printers and Faxes I see it's marked "Offline" and the printing job is stacked. Checking connections etc shows everything looks OK. My only option is to uninstall then re-install the software. Takes an hour. Very frustrating. I use Windows XP.
i missed f380 driver
  • Anonymous Mar 14, 2008
    I was missed my hp deskjet f380 model printer driver. So, I need get back driver, How.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    do you need the driver?
    Guru:
  • 377 Answers
Hi dear
this link for your driver
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40457-1&lc=en&cc=us&dlc=en&product=1128296&os=228
oke....
post in me back
thks
ropp
Posted on Mar 16, 2008
2 Suggested Answers
SOURCE:
Khalsa007
  • 79 Answers
SOURCE: My HP deskjet F4810 printer keeps going offline
As described by you , there might be an issue with teh spooler service of your computer , u can follow the undermentioned steps that might help you.
  1. Open a Command Prompt window
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem)
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there. By default, this is where the print spooler stores print files.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
  1. There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
  2. Then click the plus sign against PRINT PROCESSOR, which is under DRIVERS and make sure there is only one entry i.e., WINPRINT. If there is any other entry, just remove it.
The spooler cleaning is complete.
now reinstall the printer .
Posted on May 29, 2008
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet 895Cxi suddenly won't print. Nothing happened, it printed perfectly one day, the next it didn't.
try control panel and diagnostic in printers and test page. also check usb wire pinched cat chewed ect
Jul 07, 2009 | HP DeskJet F380 All-In-One Printer
My HP Deskjet D2360 keeps going offline. What
First try reinstalling drivers for your printer from original CD, if that doesn't help update your drivers from the Internet.
If none of it helps, try connecting your printer to another computer and see if it will behave the same. If it does, then printer is ready for retirement.
May 04, 2009 | HP DeskJet F380 All-In-One Printer
My printer wont print from the computer.
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Mar 16, 2009 | HP Deskjet F340 All-In-One Printer
Wont print
Right click on the printer deselect the use printer offline
Mar 08, 2009 | HP DeskJet F380 All-In-One Printer
I have a HP Officejet 6300 and it is showing as Offline
go to control panel, then printers and faxes, then right click on it and click "use printer online"
hope this helps!
Jan 25, 2009 | HP DeskJet F380 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
key the commands
net stop spooler
key the commands
Mar 06, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
1,050 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
