Nokia N95 Cellular Phone Logo
Posted on Mar 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mobile shutting off on NO ANSWER CALLS
Once the called number do not respond, after finishing the full rings my mobile gets stuck for at least 3-4 minutes and then automatically shuts down and re-starts. Anyone out there knows what to do? During this period it is not possible to make or receive any other calls.
  • Anonymous Mar 15, 2008
    If a number is dialed on my phone, it always reboot itself but if there is no SIM card on it, it functions well.
    (N95 CHINA MOBILE phone)
    by: Moses Ogunfowote
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Mar 15, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
24065
Points
176
Format ur phones,and restore full factory settings it will work if not i suggest u more
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
4helpful
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Answermachine not picking up
I emailed Motorola support. Email bounced back and was redirected to their broadband support. Not what i needed at all. Tried again, same result. Gave up in the end and contacted BT who round a fault at the exchange which was blocking my Caller Id. Once they fixed this, the answer machine worked too. Weird. Especially as I plugged in an older phone earlier to test it and the answer machine on that one worked. Nil points to Motorola for support I have to say....
My HTC P3450 mobile was not responding to few calls while the callers could here my mobile ringing.I couldn't see any kind of response from my mobile to receive such calls.Even, i couldn't know that they...
Completely swith off, then switch on. Wait HTC takes a bit more time to respond. Put on vibration mode or put in full ring and alarm mode. This should work.
1helpful
How do I divert calls from Console to mobile KX-T7636
Press the Program button. enter 50 for call forwarding and press Enter. enter 2 and the number (ie 25551234) to forward ALL calls to the specified number. enter 3 and the number to forward when busy, 4 and the number to forward when there is no answer, and 5 and the number for when you're either busy or there is no answer. Hit Enter and then the Program button again.
Not receiving all my calls
have u done a handset reset for your smart phone yet?
Jan 05, 2009 • HTC G1
How do I undivert an extension?
Oh, the old forward to two destinatons trick :-)
If you're happy with the destination for C.O. Calls, you can set only the intercom call forward. There are *71xx codes that you dial. The 3rd digit is 0 for all calls, 1 for CO calls and 2 for itnercom calls.
The 4th digit can be 0/2/3/4/5 where zero is cancel, 2 is all, 3 is busy, 4 is no answer and 5 is busy/NA. The next digits are the destination which may also include an access code (9) and then #.
So, example to forward all intercom calls to voice mail (if 500) dial *7122 500 #. If the location for both calls is the same you can also reset everything by dialing *7100# then *7102 500 #.
Carl
No respond to incoming calls
go to phone settings. check the profile and change it accordingly..regs
N95 8GB 'withheld number' on all incoming calls
contact your mobile service carrier and explain what is happening with the incoming calls it could be a problem from the carrier end.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
