Question about Sony PlayStation Portable (PSP) Console
Psp problem my psp won't allow you to connect to www network also if you go to rss and try to type text it just continues to keep scrolling fast through the letters.
  • pashuk Mar 29, 2008
    The main menu on my PSP is moving to the last subject of each topic.
  • robones Apr 15, 2008
    my psp will stay on (when pluged in ) for only 15 min. I cant even charge the battery. I turned off all setting in the battery systems. My email is
    [email protected]
  • 3 Answers
Probably one of your arrow buttons is stuck for the"one other user".
But only in rss i dont know??
Posted on Mar 31, 2008
SOURCE:
How to update my jxd1000
1.Connect your PSP to an electrical outlet using an AC adapter. Turn on your PSP system. Enable the PSP to connect to the Wi-Fi network by flipping the "Wi-Fi" switch on the top of your PSP.
2.Scroll over to the "Settings" section of the Cross Media Bar and scroll down to select "Network Settings." Select "Infrastructure Mode" from the next screen. Connect to your wireless network or follow the onscreen instructions to set up a new wireless access point.
3.Scroll up and select the "System Update" option in the "Settings" section of the Cross Media Bar. Choose the new PSP firmware from the following screen. Press the "X" button to confirm that you wish to update your PSP firmware; allow several minutes for the download to complete. Your PSP system will reboot after the download and installation is complete.
Thanks for using Fixya.Have a good day.
Apr 01, 2012 | Computers & Internet
Tip
How to set up internet for psp
Your PSP will detect any wireless wireless network within its range as long as the wireless adapter is switched on. The switch for this is on the left end of the PSP, near the analogue thumbstick. If the switch is in the down position, the wireless network adapter is off; push the switch into the up position and it'll turn it on. If you're not going to be using wireless networking it's a good idea to keep it turned off as it'll make your batteries last longer.
When you turn on your PSP's wireless adapter it'll look for any wireless networks nearby. If there's another PSP within range it'll automatically set up what's called an 'ad-hoc' network between the two. This will enable you to play multiplayer games between the two PSPs with one hosting the game and the other joining it. When you want to join an existing wireless network, such as when you want to browse the internet, you'll be using an 'infrastructure' wireless networking mode.
To connect to a wireless network, go to the home screen of your PSP and look under Settings. If you scroll all the way to the bottom you'll find Network Settings, so enter this and on the next screen you'll be asked to choose between Ad-Hoc and Infrastructure, so pick the latter by selecting it and pressing X. Press O to return to the previous screen. You'll need to set up a Connection. You can save the settings for 10 different Connections and you can choose between the Connections you've set up whenever you need to use the Infrastructure network mode.
Pick New Connection and press X. You can give the new Connection a name by pressing X and using the text-entry screen. Give it a descriptive name like 'Home Network' or 'University Network' so you know when and where you can use it. When you've entered the name for your new Connection you'll be asked whether you want to scan for WLAN settings or to enter them manually; select the Scan option and press right on the directional-pad. Your PSP will then scan the area for any available networks and collect the settings needed. A list of available networks (called Access Points) will be displayed, giving its name (called an SSID), whether it's encrypted or not and the signal strength. If there is more than one network, use the D-pad to scroll down to the one you want to join and press X. You'll be asked to confirm the settings so press right on the D-pad to scroll through each. When you get to the security settings, choose the appropriate setting from the list, which is WEP in most cases, and press right on the D-pad again. If you need to enter the WEP key, speak to whoever runs the wireless network and they'll provide it for you. Press X and enter the WEP using the text-entry screen.
Once you've done that you can check the settings you've entered on the final screen and save them. Now you'll be able to connect to the wireless network. If you return to the main home screen you can now update your PSP's software by going to Settings and selecting Network Update. Alternatively you can go to the Network section on the far right of the home screen to browse the internet using the PSP's in-built internet browser. Or you can fire up that multi-player game you've been itching to try out and get going!
on Mar 20, 2010 | Video Game Consoles & Games
Tip
Watch YouTube videos with PSP - Online.
Getting online with your PSP is very simple. First, you must be in range of a Wifi hotspot (wireless local area network). You can adjust network setting to connect to an access point such as a Wi-Fi hotspot or the router on a wireless home network and save the network connections data on your PSP®. Up to 10 connections can be saved.
Hotspots can be found in airports, hotels, restaurants, and at home if you have a wireless network. Once in range of the hotspot, go to "Settings" menu, >> "Network" Settings and press "X" Button. Select "Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the "New Connection". For details about Infrastructure Mode set up, or Ad Hoc Mode set up, visit us.playstation.com.
Search for networks in range. You will usually need a signal of at least 40% to connect - the higher the percent, the connection will be faster. If the connection is successful, information about the network connection will appear.
Once your PSP® is online, you can: Play multiplayer online games with Infrastructure mode, Download individual files, Download a PSP® Content Pack, Surf the World Wide Web, Check out the Official PSP® Website http://www.psp.playstation.com, Enjoy RSS video or audio web feeds, weblogs or podcasts from any of thousands of websites, and Update the PSP® system software.
Watch YouTube videos directly on your PSP
Before using PSPTube you’ll need to sign up a dev account at YouTube’s developer page: "http://youtube.com/dev". then, ... Read more....
on Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Can someone please tell me how to connect to the internet so I can send text messages on my psp?
For this you need a broad band connection.Now switch on the psp go to settings go down fully and enter network settings and enter infrastructure mode.There select [New Connection] and you will enter WLAN settings there select scan.While doing this remember to do this switch on the broad band so that the psp will be able track it while scanning.After it finds your WLAN it will show you the SSID,Security and signal strength.Then press 'x' and type the SSID and press the right arrow to continue.Now you mus type the security code if you have one otherwise press none.Then select the address settings to easy or custom and keep going front until you find the sentence 'Press the x button to save settings'.Now you can browse the internet with the connection.But remember to switch on the broad band when you want to browse the internet.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
Connecting to internet
The way 2 do it is :
first u need an internet connection router like sky broadband. Then u need 2 turn on ur psp wlan switch on the left. Go to th psp internet. Make a new connection. Once u clik scan u should find ur router. The way 2 know if its ur router is the number located on the back of ur router. Go next and it should ask 4 a wep key or some ting like dat. The code is also located on ur router. once u have typed it in and saved it, u should have ur connection and be able 2 surf da net on ur psp. The closer u r 2 ur router, the strionger the connnection will be. i hope dis helped =)
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
How to connect wifi network on my psp in india
well its a universal connection type. So you can still follow the standard guide. If this doesnt work let me know at what step you get an error and what the error code is. step 1 Your PSP will detect any wireless wireless network within its range as long as the wireless
step 2 When you turn on your PSP's wireless adapter it'll look for any wireless networks nearby. If
networking mode.
step 3 To connect to a wireless network, go to the home screen of your PSP and look under Settings. If
step 4 Pick New Connection and press X. You can give the new Connection a name by pressing X and using
step 5 A list of available networks (called Access Points) will be displayed, giving its name (called an
step 6 Once you've done that you can check the settings you've entered on the final screen and save
Now you're online, if you need further assistance or get an error code please let me know and i
will be glad to assist you further. Thanks-Midwest-tek
Jan 17, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP
Well it look like you might not have a WiFi network connection set up yet on your PSP. So This is what you want to do if you have DSL at home and a WiFi router. When you search for a new network connection and you find the one from your home, you will still need the WEP key wich is the most inportant in order to allow you PSP to use that WiFi connection. That must be why you are getting this error messege
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Psp won't allow me to add info to address bar
You have to use the "Internet Browser" Under "Network". If you have a password, try to disable it.
If you use it by any other way, for ex. the "internet radio" or "RSS", all of the major settings are locked.
Aug 18, 2008 | Video Game Consoles & Games
Acessing internet from my psp
Aug 12, 2008 | Sony PlayStation Portable (PSP) Console
Internet
Aug 11, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
