Question about Kitchen Ranges
I have a white westing house oven not sure of the number of model. Anyway the oven has locked and I can't remove the sign and get the oven working. I have had an electrician out and they were unable to unlock it either. Do you have any guideance or advice. It would be much appreciated. I look forward to hearing from you. Cheers Linda
  • 1,894 Answers
Do you say that your oven has got stuck?
Posted on Mar 12, 2008
  • dewan nafees ahmed Mar 13, 2008
    you will have to do a reset for the oven.
    this instruction for reset can be obtained form the service manual
    so please get the service manual and keep working.
    thank you
Get the lock off to close the oven door..I pressed clean by lock is on, but door is open?
Unplug it first to see if it is an electric lock. If that does not work please post the model number.
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
White westinghouse range
A model number would help, but if it's really old, information may not be available.
If this is a simple mechanical lock which you're supposed to be able to lock and unlock by hand, maybe it's rusted. A penetrating oil like PB Blaster may help.
If it's a relay-drive lock that's controlled by the circuit board, then it may need board repair, etc.
Jun 08, 2013 | Microwave Ovens
I have misplaced the manual for my oven and I need the self cleaning instructions. Model # RF365PXDQ0 Serial # FE2007966
First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
The manual is available here: . If the direct link doesn't work, start here: and enter the model number and then click Go.
I hope this helps.
Apr 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a westing house electric wall oven. having trouble removing oven light to replace
Remove the fuze or switch off the oven circuit breaker in the electrical meter box to make sure power is off.
Remove protective glass cover. It usually unscrews. Even tap with a piece of wood. Unscrew the globe. If globe has broken it still needs to be unscrewed.
Jan 03, 2011 | Ovens
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
White westing house stove cant open oven door
try pushing self clean then cancel or stop/clear
Jun 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Microhood turntable not working
You can find an exploded view of your microwave at (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
