Question about Motorola Mobility i880 Cellular Phone
VOICE DIALING IS MY PHONE CAPABLE OF VOICE DIALING AND HOW DO I USE IT IF IT IS? I HAVE A MOTOROLA BLUE TOOTH AND WHEN I TRY IT IT SAYS NO VOICE TAGS
    Novelist:
  • 119 Answers
Dear chuckbonus
Please find below the complete manual for your phone. The phone is indeed voice tag capable. You will find the information requested at page 43 of the user's manual.
http://www.cellphones.ca/upload/manuals/motorola-i880-manual.pdf
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Posted on Mar 31, 2008
I have a droid x and i cant listen to voice messages or music thru my blue tooth... any suggestions.
Check your bluetooth and make sure that it is capable of playing music through the headset. I had a Motorola Bluetooth headset that was unable to play music through it, but I later then upgraded to a Plantronics headset, and this played music just fine.
http://www.plantronics.com/us/product/voyager-pro
As for not being able to hear voice messages through your bluetooth headset, make sure that the volumes are up on both the device and the headset, and try deleting the paired device and re-pairing it!
Feb 25, 2011 | Motorola Mobility Droid X
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
Does the lg vx4650 have blue tooth capability for hands free
Looking at the spec sheet for it www.lgmobilephones.com it does not have bluetooth, but does have voice activation.
Jan 24, 2009 | LG VX4650 Cellular Phone
Pairing a motorola n136 with a lg vx5500
your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Jan 09, 2009 | Motorola Mobility HS850 Consumer Headset
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Will not voice activate
Does your Treo 700W support "voice dialing"? I searched the whole user guide for the Treo 700W and it does not say anything about dialing by voice. If the phone does not support it than no matter what Blue Tooth unit you use you will not be able to voice dial.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
MOTOROLLA E815
Here is a link for your phone at motorola.
If you cannot get there by just clicking the link, then copy and paste.
http://www.motorola.com/mdirect/manuals/e815VZW_9491A79O.pdf
Or just copy and paste the main www.motorola.com
Feb 24, 2008 | Motorola Mobility E815
Motorola Mobility i880 Cellular Phone Logo
189 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
