Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint wf840 displays "test"
When I try to run a cycle, the machine displays "test", goes through the test then displays "on", and then when I try again it just does the same thing. Help! please.
  • 5 more comments
  • Anonymous Mar 27, 2008
    i tried
  • Anonymous Apr 14, 2008
    i have a wf840 washing machine and in the disply it sy test could you call me please
  • sars69 Apr 21, 2008
    I have a hotpoint wf849 and have an error message TEST on the screen that wont disappear and my machine wont work. please help, thanks
  • Anonymous Apr 29, 2008
    my hoover wf840 keeps going onto test cant get it to wash
  • Anonymous Aug 21, 2008
    well mines a wf860, was doing the same thing, the solution below worked 1st time tho, thanks :)
  • Anonymous Sep 16, 2008
    I have exactly the same problem test keeps coming up everytime i try to wash. I tried the solution and it worked a treat thanks very much!!! you saved me £100 call ouyt charge
  • Anonymous Nov 15, 2008
    washing mashine stuck in demo mode
  • 16 Answers
Try This - It works for the Washer Dryers so it May work on your Washer.
  1. Press the Start/Cancel button until all the console Led's Illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Hope this Helps.
Posted on Mar 16, 2008
    New Friend:
It worked for me on the WF840. Thanks.
Posted on Feb 26, 2013
Hey - this worked fine on the WF 630 model too model too - ta!
Posted on Jun 04, 2008
It worked!! thanks alot
Posted on Sep 07, 2008
Front loader hotpoint wf840 running 'test' cant remember how to reboot. last time i had to do this i had to hold down one of the buttons for a few seconds and wait till a specific word came up on...
Here are the instructions to (just) clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
My washer (hotpoint ultra silent wf840) is displaying f-08 on it's digital display, can anyone help please.
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Feb 23, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Displaying test sign
Hi, to exit the DEMO/TEST mode, press and hold down the "On/OFF" and "Start/Cancel" buttons until "d off" is displayed
Take care
Jun 20, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840 displays h20 all the time
This is indicating a problem with the water supply to the washer.
Check inllet hose/s, make sure they are not kinked or restricted , make sure tap/s are fully turned on.
Make sure water presure is o/k.
Mar 18, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
WE HAVE A HOTPOINT WASHING MACHINE WF840 . THE DISPLAY KEEPS READING TEST AND WILL NOT PPROGRAMME .
unplug for 15 min letting the computer reset then try again if that does not work call the installer.
Apr 13, 2008 | Washing Machines
Test
When it is turned on, press the On/Off button and the Start/Cancel button at the same time until the display reads "dOff". This worked for my washing machine after repeatedly displaying "Test" and doing nothing else.
Nov 20, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Displays F-03
NTC fault its electronic and needs engineer
But try this for most electronical faults first switch off mains wait 20secs and switch back on this resets most gadgets and gizmos if it doesn't work it was a free try.
Nov 07, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
535 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
