Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch KGV2620GB/03 Hi, I have a Bosch KGV2620GB/03 fridge freezer (bottom freezer, free-standing, the product listed below isn't right) and the light in the fridge won't switch off when the door closes. Any ideas? I assume it's something to do with the switch that registers the door has closed, but not sure how to fix. It's an electronic control, so there's no temperature wheel/switch inside, and we don't have the user guide (which I also can't find online!). Any help much appreciated. Dan
    Genius:
  • 1,036 Answers
If it is the one I am thinking of, then the whole light assembly is actually able to move and this also acts as the switch.
Turn off the appliance and unplug.
You should be able to prise the whole assembly out to check the contacts at the back. Try just pulling the light unit downwards and out, and see if you can see the switch. Use a small screwdriver at the points indicated with a triangle.If you can't see the switch - prise the surround out also.If you cannot get to them because it is a sealed unit, you may have to break it apart to solve the problem. Use a glue suitable for polystyrene to repair it (model shops sell this).
If it will not repair well, you need to replace this part - but you tried.
Posted on Jan 10, 2009
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 | Freezers
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
The bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Jun 30, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
We have a free standing bosch fridge/freezer, the freezer is at the bottom. Ice is forming in the bottom of the freezer, underneath the last drawer.
sounds like the drain hole in the back of the freezer has blocked and when the defrost kicks in the water is not running out of the drain hole but into the bottom of the freezer. best do a full defrost and if it occurs again the drain hole will need to be cleared out.
Mar 19, 2009 | Bosch Refrigerators
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case...
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Jan 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
136 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
