Question about D-Link AirPlus DI-524 Wireless Router
I've just put in a d-link wireless router, but when trying to get to the website 'http://192.168.0.1/' the computer cant find the webpage? Whats wrong?
  • 3 more comments
  • muffin88 Mar 12, 2008
    The internet is fine if thats what a isp provider is. i dont no much about computers. I just can't get on that page to put in my passwords and such to get the wireless router working
    Ahh i dont no what any of that stuff is sorry. lol probly y i dont have it working yet
    Im not too good with computers, so i dont no how to configure it
    Ok i found all that info and its all rite on my computer. those numbers r what's on the subnet and nic ip.
    I've already tried cmd and ipconfig. No matter what numbers i type in the address or how its typed it still wont come up.
    Genius:
  • 1,027 Answers
Make sure the router is disconnected from the modem before continuing.
In winXP go to start
click on run
type in CMD press enter.
from the command line type in ipconfig press enter.
the default gateway will be your routers ip address.
Posted on Mar 12, 2008
Please check your NIC IP Address and Subnet. The IP Address should be in the range of your router's IP Address. Some routers have been disabled the DHCP capability so you should enter your IP manually.
If the router has an IP of 192.168.0.1
Your NIC IP must be 192.168.0.x and your subnet must be 255.255.255.0
Hope This Can Help.
    Problem Solver:
  • 9 Answers
Still not working contact the isp provider might be a problem with the isp provider
    Problem Solver:
  • 9 Answers
You just try to configure and then try connecting
D-Link DI-514 Router Firmware Upgrade Error Message
This is an old post, but just in case someone else needs this...
The dlink website for the Di 514 rev B version actually links to the rev C versions' firmware. I got the same error.
browse to here ftp://ftp.dlink.com/Gateway and grab the right version for your rev B device.
Best,
Kevin
Oct 04, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
Can a talk talk router be changed for a d link aol router
as long as its a asdl router,..goto webpage in your aol router,.and put your talk talk username and password,.in,...and press connect.(on that webpage).its that easy,...to get to the router webpage,..in your browser type 192.168.0.1 or whichever is shown written on sticker,on your aol router.
Sep 15, 2017 | Computers & Internet
Whats my routers hex key
The encryption (hex) key is in the router's wireless settings.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Belkin to the LAN port on your computer.
Open a browser and enter the Belkin configuration URL
http://192.168.2.1
The default PW = blank (just press enter)
You can protect your router by changing the default PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Apply these settings to the wireless card in your laptop/computer.
Connect your DSL or cable modem to the D-Link router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 14, 2011 | Belkin (F5D7230-4) Router (587009)
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Hot to use LINKSYS Router as an alternate wireless acces point
this is not a wireless repeater i do beleive this is what want. You need a router or gateway with this function. look at this product http://www.linksysbycisco.com/US/en/products/WGA600N
Feb 20, 2009 | Linksys Wireless-G WRT54GS Router...
Cant get to the router webpage.
Try admin as the password and username.
That is the default password. Please make sure you reset the password once you get in as to keep your router secure.
Thanks
Dragonrdrz
Please rate me!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/rick_eeed4a91077c64e8
Jan 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant access http://192.168.0.1
Make sure your web browser is not set to use a proxy or any firewall it is blocking the connection, then try to go to http://192.168.0.1 again.
If it still fails, try from a different machine on the LAN. If that still fails, then try restoring factory defaults to the router.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet Won't Work on PSP
i finally got my D-link WBR-2310 i found out ..
what you need is to do is Uncheck the box on the 802.11g Only Mode uncheck then you will be able to use psp online.
Good luck.
Dec 29, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link AirPlus DI-524 Wireless Router Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
