Question about Xerox DocuColor 12 Printer
XEROX 5360 PASS WORD RESET
    Champion:
  • 241 Answers
Fiery.1
case sensitive
master password
Posted on Aug 19, 2010
SOURCE:
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
I cant get a network signal on my phone its a samsung galaxy s 5360 how do i fix this ive tried sim and all usual t
turn off WIFI; reset network settngs; make sure cellular data is turned on by going into Settings>network>mobile networks>mobile network>make sure this has a checkmark. call carrier and have them cancel the registration on your phone. call them from a different phone and have your Galaxy turned off .
Oct 19, 2012 | Samsung Y GALAXY S-5360
The machine's admin password has been lost/forgotten. Is there anyway I can reset the password?
it can be reset in diagnostics. Hold down the # button and hit the Access button. That pass code is 1934. Reseting the admin passcode for the tools menu is in there some where.
Sep 23, 2010 | Xerox WorkCentre 4150 Black and White...
Need to reset an account in the job templates, and
When you browse in via the IP address, the Centreware Internet Service (CWIS) will ask for your username and pass word for certain operations. On the 7132, the username is 11111 and the password is x-admin (all lowercase). If that does not work, it may be that you exceeded the login attempt limit and will have to power off the machine, wait 1 minute and then restart it. This process usually takes less than 3 minutes total.
Apr 14, 2009 | Xerox Office Equipment & Supplies
Xerox ducuMate 152, password recently does not work
You could reset the device, that usually resets everything - the downfall is that you will have to re-configure everything.
  1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu.
  2. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 152 scanner.
  3. Click the Properties button.
  4. To return the scanner to its factory settings, click Reset Device.
  5. Click OK to save the changes and close the dialog box.
If this doesn't fix the problem please post a comment, I will do some more research into it.
Mar 20, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Power adaptor
Look for the label located at the bottom of your Modem (SpeedStream 5360) RATTING: 18VAC: 0.8A 50-60Hz, it is using 18V 0.8A Power Adaptor.
Dec 23, 2008 | Efficient Networks SpeedStream 5360 Modem
INSTALL A MODEM
The 5360 is techncially a bridge, not a modem, so it doesn't require software drivers for installation and operation.
There is a 5360 firmware upgrade, but it should only be used in certain situations -- see Related Articles at right for further information.
Note that DSL and cable bridges are often called "modems" because that is the familiar term for a device that connects the residential user to the ISP.
Please refer the link below:
http://kb.efficient.com/display/1/articleDirect/index.asp?aid=45459&r=0.9242823
Also refer the FAQ for 5360:
http://www.broadbandreports.com/faq/eff/6_5360
Thanks
Aug 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5360 modem
  1. From the System area, , select Network Settings.
  2. Select Edit Settings.
  3. Select Additional Settings, and then select PPPoE Settings.
    1. Enter the PPPoE information provided by .........on the screens for: .......
    2. User Name ......
    • Password
    • Service Name
    1. Select Done. When prompted, select Test Xbox Live Connection.
    Feb 19, 2008 | Computers & Internet
    Xerox DocuColor 12 Printer Logo
    219 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Clive
    Clive
    Philip Hughes
    docukaaf
    Level 1 Expert
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
