My printer was disconnected and when reconnected the output is cramped line on line. I have deleted the printer several times and reinstalled it but to no avail. How can I sort this problem out. Your help will be very welcome. Regards Keith.
  • Keith Southern Mar 12, 2008
    Hi Terry, I only disconnected my Canon BJC2000sp for about two hours while I installed Canon MX300, a three-in one. When I tried to connect the cable from the computer, I had it wrong way round. The contacts touched briefly, maybe I fried something....? Regards, Keith
    Sergeant:
  • 349 Answers
It seem that the printer has got lazy since it was disconnected ,try running a few pages through it to try and loosen it up ,also give the roller a clean it may not be griping the paper correctly
hope it helps you
Terry
Posted on Mar 12, 2008
Why does my 7520 printer print old documents.
Your computer has "queued" various pages to be printed.
When it detects that it cannot completely complete the output, it restarts the sending of the information to the printer.
From the Windows "Control Panel", select "Printers".
Select your printer. Click to "show what is printing".
From there, you can select an item, and choose to "cancel" it.
Mar 02, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Cant print..it keeps on giving the error code 79 even after turning it off and on
turn printer off; disconnect network/usb cable. clear printer cue. turn printer on. turn off; reconnect network cable/usb cable. try printing test page. may need to delete and then reinstall new printer driver.
Feb 17, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
When I print, on the paper there is several blue verticle lines at the top of the paper and halfway down and some of the lines are broken. Thankyou Tom
Reset the Printer If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product. Make sure the product is on, and then disconnect the power cord from the product.
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  3. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  4. Reconnect the power cord to the product.
  5. Press the Power button (c02062868.gif ) to turn on the product. If you have duplexer try to open it and clean the rollers of the printer and the duplexer. This usually happens if the rollers are dirty.
Mar 26, 2011 | Office Equipment & Supplies
Can no longer access Supply Levels info when checking on ink cartridge status. Message = "Information Not Available." Used to be able to see graphic showing tank levels.
You might have to delete the printer tools software and the printer driver and reinstall. Also turn off the printer disconnect the usb and reconnect after you have reinstalled the printer drivers and tools. see if there is an updated driver on the manufacturers website.
Jul 31, 2009 | Canon Pixma MP500 All-In-One InkJet...
Its not printing
First, disconnect and reconnect the printer cable. If no difference, try reinstalling the printer driver by deleting your printer icon, disconnecting the printer cable, reconnecting the cable and see if the printer is found. Then, install the printer driver. Good luck.
Jun 15, 2009 | HP Officejet 4315 All-in-One Printer
Printer stalls when sent a print job.
I'd suggest reinstalling the printer driver.
In Start - Printers and Faxes, find the printer and delete the icon. Power off the printer and disconnect the cable from the printer to the PC. Restart your workstation and log in. Reconnect your printer cable to the PC. The printer should be found. Install the driver and the printer should work. Good luck.
Jun 12, 2009 | Samsung CLP-510 Laser Printer
Recurring "cartridge successfully installed" message
Download the Kyocera Driver Deleter tool from here:
http://drivers.softpedia.com/progDownload/Kyocera-KM-Deleter-281031-Download-18304.html
Run the tool and delete the driver for your HP. Disconnect the printer, then use Add/Remove programs to uninstall the HP software.
Reboot.
Reinstall the HP software and reconnect the printer when prompted by the software install.
After this I didn't get the message again.
Hope this helps!
Mar 18, 2009 | HP Officejet 7210 All-In-One InkJet...
When I hit 'file' then 'print' nothing happens
Go to your device manager and make sure that you have a driver for the printer. Or uninstall the printer then reinstall it. sounds like the printer driver has been deleted
Feb 10, 2009 | Dell 924 All-in-One InkJet Printer
Reinstall software each time the printer is reconnected
hmmm...maybe the way to do this is to use the remove hardware icon in control panel, instead of simply disconnecting the printer from the laptop.
also, go to www.hp.com and get the newest drivers, which are almost certainly more recent vintage than those on the cd.
Aug 20, 2008 | HP Photosmart C4280 Aio Printer
LED BLINKING
Replace the communication cable (parallel cable).
Dec 11, 2007 | Epson FX 1170 Matrix Printer
Computers & Internet Logo
David Payne
David Payne
