Error to Detect, hardisk must be formatted
I have external hard disk 2.5" SAMSUNG HM120JC with 120 GB. When I connected into my laptop/PC, this hard disk can be found as a local hard disk. Then i double clicked this drive (hard disk), my laptop/PC asked me to format it. In this case i need the data inside (117 GB). What should I do? I've tried to use some recovery softwares, but they didn't work. So what's wrong with my hard disk?
Thanks
    Scholar:
  • 119 Answers
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Posted on Mar 12, 2008
Need to reformatt
Just connect ur external hardisk with your pc through usb cable, the right click on the hardisk and click on format
Sep 11, 2011 | Western Digital WD Passport 250GB Portable...
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
I have transcend 320 gB J25c external hardisk.I bought this recently.I pluged this to linux and window systems six or eight times and all of systems detect transcend disk.But the next day morning,I pluged...
Try checking your connections. Make sure the usb cable is firmly in the hard drive as well as the pc. Unplug the hard drive, restart the computer and plug it back in. If that does not work I would suggest trying some sort of file recovery/back up software and then calling in the warranty.
Jun 10, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My hardisk showed 2000-0146 error and it got replaced with new harddisk.. can i recover data from my old harddisk?
Try connecting the hard drive to an USB hard drive adapter and connect it to a computer's USB port. The computer should see it as an external storage device and you can open the various folders and files to backup your data.
If the computer cannot detect the hard drive as an external device then the hard drive is faulty.
If the hard drive makes a clicking noisy then it is definitely faulty and replacing the circuit board cannot fix this problem.
There are companies that can retrieve data from a faulty hard disk BUT it will cost you an arm and a leg for their services.
Jan 24, 2011 | Dell Latitude D630n Notebook
I could not hardisk detect on pc when decting hardisk,please boot another disk
Check that the "data" and "power" cables to the disk-drive are fully-connected to the disk-drive.
Check that the "data" cable is fully-connected to the motherboard.
Enter BIOS SETUP, and check that the motherboard has detected the disk-drive.
Otherwise, your disk-drive has "died", and must be replaced.
Aug 01, 2010 | Samsung (SP1203N) 120 GB Hard Drive
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
My external hardisk is showing in device manager but it is not showing in disk manager
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your bios settings
Feb 03, 2010 | Toshiba MK6034GAX (HDD2D17) 60 GB Hard...
My hardisk 1tb only shows 500gb space, just bough it yessterday and i have installed it in port 0 and an other hardisk off 500 gb was installed on port 1 and when i go into my computer i only see both...
If you're using the original XP version it wasn't able to format the correct size of the hard drives. You need to find a version with Service Pack 2 and boot off that CD in order to format the correct size of the drives. You could also boot off a Vista installation CD and format the correct size.
Oct 01, 2009 | Western Digital 500GB My Book Pro-External...
My external Samsung HM120JC 120 GB Hard Drive not responding
Not sure what could be the problem.
There are many issues here.
- Did this drive worked before?
- If it did, was this your boot drive?
- USB cable and connector problems
- How is this connected to the drive?
- Is it in a package that came with the drive complete, or you had to install it?
My two cents... Samsung and other Japanese drives are not that reliable and if it's new, return it and get a Seagate drive. They have five year warranty and much better drives.
Apr 08, 2009 | Computers & Internet
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
140 people viewed this question
Alun Cox
David Payne
David Payne
