Question about HP LaserJet 2420 Printer
Printer takes ages to process
My printer takes ages to process document.it can take as long as 4 minutes to process a single page word -text only document
I re installed the printer drivers n voila.it worked.
brakkefluid
Posted on Mar 27, 2008
    New Friend:
  • 159 Answers
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Posted on Mar 17, 2008
SOURCE:
How to print 11X17 Booklet on CS Kyocera CS3011ikx
Kyocera printers are well-known for their efficiency to produce brilliant color prints. The printer can deliver high-resolution output with crisp black and white text and graphics. The CS Kyocera CS3011ikx printer can print multiple copies that can be folded into a single booklet. Printing a booklet can minimize cost. Read through the instructions given below to understand how to print a 11X17 booklet on CS Kyocera CS3011ikx printer.
1 Press the Copy menu on the control panel to initiate the process. Select the Layout Edit tab.
2 Click the Booklet option.
3 The printer supports single-sided and double-sided printing. Choose either of them according to the printing requirement.
4 Change Default settings and mention the size of the media.
5 Place the original document or text in the document feeder.
6 Press the Start button.
7 Select the appropriate print size. Modify the size as 11X17 to meet the booklet requirement.
8 Change the page size.
9 Open the PDF document.
10 Select the options File> Print. Choose your printer from the list displayed on the screen.
11 Cut and staple the edges of your booklet. Trim the ends of the pages if it is necessary. Call our Toll-Free 1-866-293-9220
Sep 26, 2018 | Kyocera Office Equipment & Supplies
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
I have got a DCP-110C printer, how do I scan a document onto the computer then alter the text within this document?
Try this procedure and let me know how it goes
  1. Scan the page you want to convert into a Microsoft Word document.
  2. Save the scanned image in *.gif, *.jpeg or whatever format.
  3. Open that image, go to "File->Save As" and name it "xyz.tiff" in the "TIFF" format as shown.
  4. Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging"
  5. Go to "File->Open" and open your scanned document that has been saved in *.TIFF format.
  6. Go to "Tools->Send Text to Word." You will get a prompt stating this process will take time, Click OK. This will take some time depending on your computer's speed (a minute or two at the most).
  7. When it's done it will open up Microsoft word on its own and the scanned document will now be in editable mode.
Sep 26, 2009 | Brother DCP-110C All-In-One InkJet Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Scanning multiple pages as a single document
The pages you scan in are each individual "pictures" which are very different than the text in the everyday word processing file. What you can do is to make a new word processing document and insert each of the scanned pictures into this new document in order. This will allow you to print all the pages in one job by printing the word processing document. As far as I know there is no way to scan all of the pages into one single file.
Carl
Dec 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Very, very slow printing
I don't know the make/model of the printer, but I can mention a few possibilities.
1) If your printer is set for PostScript (PS) language, versus PCL , it normally takes longer to print.
2) If this printer is fairly new, check for old Printers installed that are no longer connected to the computer/network. See if there are still print jobs in the queues. A missing printer with jobs still in queue will keep polling the system and eating up processing time.
3) If this printer is a laser printer, it may have to wake-up and warm-up before printing.
Nov 23, 2008 | Acer Aspire 5100-3357 Notebook
HP LaserJet 2420 Printer Logo
1,718 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
